11-15-2017, 07:30 | #16 (permalink) |
Freak Poster Join Date: Jun 2013 Location: india tirupur tamilnadu
Member: 1962832 Status: Offline Thanks Meter: 199 | solved my problem Best Regards a1mobiletirupur * Always Follow Forum RulesHere * Use Only Thanks Button * Use Search Button Before make a Thread |
The Following 2 Users Say Thank You to a1mobiletirupur For This Useful Post: |
11-22-2017, 09:42 | #18 (permalink) | |
Freak Poster Join Date: Jan 2015 Location: Dhaka Bangladesh
Member: 2333595 Status: Offline Sonork: wwwsonork.com Thanks Meter: 120 | contact me in skype Quote:
contact me in skype i help us | |
12-16-2017, 17:12 | #21 (permalink) |
Junior Member Join Date: Dec 2017 Location: Gazipur,Tongi
Member: 2785901 Status: Offline Thanks Meter: 4 | Wait for phone... Phone found! [ 17 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 44000145313034461F9101366F165A8C Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x45 , OEM : 0100 [eMMC] : FLASH_INF : [SANDISK] , 6104F [eMMC] : FLASH_CID : 45010044463430313601911F8C5A936F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x0DA444E0FF4791B93C235D1D5D7858DE INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! |
The Following User Says Thank You to AR_Rakib For This Useful Post: |
11-13-2018, 16:13 | #23 (permalink) |
Freak Poster Join Date: Jun 2013 Location: south Africa
Member: 1960717 Status: Offline Sonork: 100.1638403 Thanks Meter: 34 | Card found : S/N : B7C2118A , v0135 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
