01-06-2018, 07:37 | #1 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Jainagar Bihar
Member: 992600 Status: Online Thanks Meter: 1,670 | NOKIA 3 TA-1032 After Flash Dead Scatter Load Ok , BaseBand : MT6737 , Project : ne1 , Storage : EMMC Files found : 15 , Set to Flash : 14 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Unknown Device Model : Unknown Device CPU : MT6737M Device IntName : Unknown Device Version : 7.0 Device Compile : 12-04-2017 AM 04:54:56 Device Project : alps-mp-n0.mp1-V1.0.2_fih6737m.35.n_P96 Device ExtInfo : Heart Ready to Flash! Start at : [06-Jan-18 / 11:25:04 AM] Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 3 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 514E011336394A32A805105273FDF74B [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2 [eMMC] : FLASH_CID : 13014E51324A3936521005A84BF74473 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x35301EC70000ADB20D42FB9D7B798AEA INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6737 , Project : ne1 , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3749 mV BL : BatteryLevel Ok SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 001B Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : BOX Image Flash Ok Flash now : SYS_INFO Image Flash Ok Flash now : HIDDEN Image Flash Ok Flash now : CDA Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:08:35 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : TEE1 Verify Passed : TEE2 Verify Passed : BOX Verify Passed : SYS_INFO Verify Passed : HIDDEN Verify Passed : CDA Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:28 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:09:15 Reconnect Power/Cable! |
01-06-2018, 11:11 | #3 (permalink) | |
No Life Poster Join Date: May 2008
Member: 770299 Status: Offline Sonork: 100.1603105 Thanks Meter: 1,029 | Quote:
http://forum.gsmhosting.com/vbb/f296...l#post12880557 | |
01-07-2018, 07:01 | #4 (permalink) |
No Life Poster Join Date: Aug 2010 Location: find me
Member: 1377174 Status: Offline Thanks Meter: 226 | https://mega.nz/#!c1c1nIyI key !T_4vE-6nz0u5U-ukjeAWMdrPlxjuG7EtiCOjJBK6IOM 100% tested daed only vibrate |
The Following 3 Users Say Thank You to samreen111 For This Useful Post: |
01-21-2018, 17:52 | #5 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 226 | Quote:
Is this something new HW? Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 15 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 510001154D33314516CF0D42AB269B68 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420DCF16689B44AB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x2629251BC43B9E33A2EA24C91BC8E41C INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6737 , Project : ne1 , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID NOT supported by BootLoader! [BL_ERROR] : BBID : Break Flashing! This Firmware will kill phone! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! | |
02-03-2018, 16:43 | #6 (permalink) | |
Freak Poster Join Date: Jun 2008 Location: mumbai Age: 31
Member: 787164 Status: Offline Thanks Meter: 24 | Quote:
02-17-2018, 14:55 | #8 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Try as what JayDi replied HERE. I will upload one more tested file to support area in a day or two. You can try that. Br. Infinity Box Team. |
01-09-2019, 07:33 | #9 (permalink) |
Major Poster Join Date: Dec 2015 Location: India
Member: 2503159 Status: Offline Thanks Meter: 14 | Nokia 3 dead after performing Identify operation. Yes!!! Identify operation. Hard to believe. I've change the battery too. Here's the log - Infinity-Box BEST Nokia [HMD] Module [NK2] v1.09 Operation : Identify [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM13) MODE : PRELOADER PORT PORT : 13 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v02.2018.1809 Fail to disable Dog! BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 13014E51324A39365210087FC5685A31 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 13014E51324A39365210087FC568C431 EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q2J96R EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 192E2CF9413CC23FF567DAB0FAFDBE92 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! --- SysInfoSub : Patch Level : O00623 Display ID : 00WW_3_38F Ver. CodeName : REL Ver. Release : 8.0.0 Sec. Patch : 2018-10-05 Build Time : 1538577343 Product Model : NE1 Product Brand : alps Product Name : NE1_00WW_FIH Product Device : NE1 Product Manfct : alps Product Info : NE1 Board Platform : mt6737m NVRMReadErr : DataRead Failed! Done! Elapsed: 00:00:41 Reconnect Power/Cable! Operation : Reset Settings [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM252) MODE : BOOTROM PORT : 252 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v02.2018.1809 Fail to disable Dog! BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Reset Settings [ v1.09 ] Before it was frp condition. To check whether best2 supports or not I hit identify operation and now handset refuse to power on. Any solution guys. Btw I've tried to flash with sp flash tool and specific da (from google) but tool throw error that "This is secure base chip". Tried holding shift key and flash too But no luck |
