10-14-2017, 10:46 | #1 (permalink) |
Freak Poster Join Date: Jun 2011 Location: jahanian punjab pakistan
Member: 1588653 Status: Offline Sonork: imran_Gill Thanks Meter: 83 | NOKIA 3 TA-1032 any xpert help Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! i chang da butt sam whats metter help any xpertsssssssssss |
10-14-2017, 11:09 | #2 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
No need change DA, ONLY DOWNLOAD THIS Package & install http://forum.gsmhosting.com/vbb/12583129-post1.html ~SP Select MODEL[6571..6797] ~Select Nokia 3,Do your work. | |
10-14-2017, 11:40 | #3 (permalink) |
Member: 1588653 Status: Offline Sonork: imran_Gill Thanks Meter: 83 | Nokia 3 ta-1032 MR Kirumira this info is same method Card found : S/N : BABD6690 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! i am try same method butt same da error |
10-14-2017, 15:29 | #4 (permalink) |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | If you selected like here http://forum.gsmhosting.com/vbb/12587575-post29.html then no LUCK,wait for update. |
10-17-2017, 15:09 | #8 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 784847 Status: Offline Thanks Meter: 45 | i have prblem identify was ok Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 514E011336394A326D051052375D773D [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2 [eMMC] : FLASH_CID : 13014E51324A39365210056D3D773437 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x676DBE7F161A3D87E83C12B18F5F80A4 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:05 Reconnect Power/Cable! i do frp reset Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 514E011336394A326D051052375D773D [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2 [eMMC] : FLASH_CID : 13014E51324A39365210056D3D773437 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x676DBE7F161A3D87E83C12B18F5F80A4 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Format/Reset Error! Operation Failed Elapsed: 00:00:44 now phone dead Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:08 plz help |
