11-15-2017, 12:42 | #1 (permalink) |
No Life Poster Join Date: Apr 2008
Member: 740220 Status: Offline Sonork: 100.1654997 Thanks Meter: 253 | nokia 3 TA-1032 boot error 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 32 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! i need also file link please |
11-15-2017, 13:25 | #3 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Bro, kindly check below link http://forum.gsmhosting.com/vbb/f296...urity-2241779/ |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
11-15-2017, 14:52 | #4 (permalink) |
Member: 740220 Status: Offline Sonork: 100.1654997 Thanks Meter: 253 | I extract winrar file and found 3 files folder. 1: Boot-GEN 2: Boot-NOK 3: Boot-SEC i put these 3 folders in cm2mtk but not succes same error as i explained before. please infinity team tell me any soltuion or way to get success. |
11-15-2017, 15:03 | #5 (permalink) |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | bro, next time use search box.. http://forum.gsmhosting.com/vbb/f296...-58-a-2242009/ |
11-15-2017, 15:31 | #7 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Hello, download this Mediatek-supplementary-files-package from here Index of pub/software/ then install select as you see here http://forum.gsmhosting.com/vbb/12587575-post29.html then do what you want |
11-15-2017, 15:50 | #9 (permalink) | |
Member: 740220 Status: Offline Sonork: 100.1654997 Thanks Meter: 253 | Quote:
11-15-2017, 15:56 | #11 (permalink) | |
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
11-15-2017, 16:10 | #13 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | FW can be found on SUPPORT AREA. Device semi-dead, seems ( if you NOT connect it with BOTH VOLUME KEYS ) Device without hold keys reboot in BOOTROM, then PRELOADER. Catch second reboot and flash it with good FW. UNTICK PRELOADER before! |
11-15-2017, 16:15 | #14 (permalink) | |
Can you give me direct link of file from support area Sent from my iPad using Tapatalk | |
11-15-2017, 16:48 | #15 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
What problem do you have downloading from support area. JFI now "Resume" feature is enabled for downloading from support area, so there should not be any problem in downloading now. Br. Infinity Box Team. | |
