12-28-2017, 19:00 | #1 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Romania Age: 48
Member: 52722 Status: Offline Thanks Meter: 18 | Nokia 3 (TA-1032) Dead after flash with Infiny. Wait a solution I belive that I downgrate...I can write twrp...root...etc BUT SUPRPRISE: I did exactly like in other post "1. NEVER MAKE FLASH ERASE!!!! You will kill device!!! 2. NOT update PRELOADER ( tick SKIP Preloader ) and NOT erase device ( untick Flash Pre-erase ) That make you 100% save from battery, connection, weather on Venus and etc." AND NOW THE CONCLUSION: After flash phone only vibrate and not power on My log: Card found : S/N : 09D2DE17 , v0136 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6737 , Project : ne1 , Storage : EMMC Files found : 15 , Set to Flash : 14 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Unknown Device Model : Unknown Device CPU : MT6737M Device IntName : Unknown Device Version : 7.0 Device Compile : 4/12/2017 4:54:56 AM Device Project : alps-mp-n0.mp1-V1.0.2_fih6737m.35.n_P96 Device ExtInfo : Heart Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 514E011336394A324305105233934D06 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2 [eMMC] : FLASH_CID : 13014E51324A393652100543064D3433 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x7184EA0567F8BF1FCBCFAA0E9D7AA26F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6737 , Project : ne1 , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 4083 mV BL : BatteryLevel Ok SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 001B Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : BOX Image Flash Ok Flash now : SYS_INFO Image Flash Ok Flash now : HIDDEN Image Flash Ok Flash now : CDA Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Image Flash Ok Flash Write Done, time used : 00:08:28 Processing : Verify Verify Passed : LK Verify Passed : BOOT Verify Passed : RECOVERY Verify Passed : LOGO Verify Passed : SECRO Verify Passed : TEE1 Verify Passed : TEE2 Verify Passed : BOX Verify Passed : SYS_INFO Verify Passed : HIDDEN Verify Passed : CDA Verify Passed : SYSTEM Verify Passed : CACHE Verify Passed : USERDATA Data Verify Done, time used : 00:00:33 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:09:15 Reconnect Power/Cable! At the time I thought it might come out of format and.....SURPISE: Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! Before the last update appeared (1.58) I made a fuul back-up (14.6 Gb), but at settings I selected SP: AUTO: [2601] bla bla [6732..6797 [[81 I83I87xx NAND I eMMC I said I was saved ... BUT THAT WAS NOT THAT !!! Files set for flashing : [ MCU ] : Nokia 3 citit infinty-MT6737M__UNKNOWN__Heart__alps-mp-n1.mp1-V1.11_fih6737m.65.nj.n1_P13__Android_7.1.1.ispff 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 514E011336394A324305105233934D06 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2 [eMMC] : FLASH_CID : 13014E51324A393652100543064D3433 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x7184EA0567F8BF1FCBCFAA0E9D7AA26F INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ISPFF ID : kia , TARGET ID : 6737 BBID missmatch! Stop killing phone!!! Select CORRECT file for that phone! Done! Elapsed: 00:00:16 Reconnect Power/Cable! this is BIG SH..T !!! OK... ... and now variants or ideas, or any firmwares 7.1.1? I belive that donwgrate is not OK. BR Mihnea |
12-29-2017, 07:08 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Remove your hand-made text in file name, until MT6737M. Then restore it back. Or use fw from support area. |
12-29-2017, 16:16 | #3 (permalink) |
Member: 52722 Status: Offline Thanks Meter: 18 | YESS MAN Yes man you were right .... I renamed the file (backup) as it saved infinty and everything was ok .. so now my phone started. One more time: * THANK YOU Mihnea |
