11-23-2017, 20:52 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: around
Member: 595864 Status: Offline Thanks Meter: 163 | Nokia 3 TA-1032 Flash Error phone came to me semi-dead, as it only connects to usb, but not turning on. flash different firmwares fom Infinity Suport and other sources, but every time same error un USERDATA. flashing was done only with CM2,as flashtool gave error. log : Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6737 , Project : ne1 , Storage : EMMC Files found : 15 , Set to Flash : 14 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Unknown Device Model : Unknown Device CPU : MT6737M Device IntName : Unknown Device Version : 7.0 Device Compile : 12-04-2017 AM 04:54:56 Device Project : alps-mp-n0.mp1-V1.0.2_fih6737m.35.n_P96 Device ExtInfo : Heart Ready to Flash! Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333145F4DF0D422580009A Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420DDFF49A005425 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x2413449587752736747B410177ABC40C INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6737 , Project : ne1 , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : Unknown (not supported or without battery) SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 001B Use FLN Mode Processing : Flash Write Flash now : LK Image Flash Ok Flash now : BOOT Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : SECRO Image Flash Ok Flash now : TEE1 Image Flash Ok Flash now : TEE2 Image Flash Ok Flash now : BOX Image Flash Ok Flash now : SYS_INFO Image Flash Ok Flash now : HIDDEN Image Flash Ok Flash now : CDA Image Flash Ok Flash now : SYSTEM Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USERDATA Write Error , code 0x001! Something went wrong! Operation Failed Elapsed: 00:08:39 Reconnect Power/Cable! ================================= also tried Format cache, userdata, but this time, no error. still dead... log : Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 510001154D333145F4DF0D422580009A Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420DDFF49A005425 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x2413449587752736747B410177ABC40C INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:47 Reconnect Power/Cable! whats wrong here ? thanks |
11-24-2017, 01:09 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | What device state? You MUST USE ONLY FW FROM SUPPORT! After flashing make WIPE mode reset. Press and hold VOL UP button with a PowerOn until color circle appear on a display. |
