08-21-2017, 13:03 | #3 (permalink) |
Freak Poster Join Date: Jul 2008 Location: bahawalpur pakistan
Member: 821900 Status: Offline Thanks Meter: 26 | nokia 3310 usercode its work for me [QUOTE=Jaits work for meyDi;12642549]Reset UserCode in BEST will do that.[/QUOTE nokia 3310 usercode its work for me |
10-28-2017, 12:59 | #4 (permalink) |
Insane Poster Join Date: Apr 2014 Location: Shop # 34 HafeeZ Center,
Member: 2161392 Status: Offline Sonork: 100.1677520:hafiz Thanks Meter: 50 | nokia 3310 2017 code reset Done 100000000000 ok Infinity Nokia [BEST] select option mediatek reset read user code Done! Card found: S/N : 0DA18C93 , v0118 Registered to: jahangir Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 82 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 77167E797934C3486B0DE25D1F8F4F43 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... BROM/BL stage done MT626x : Reset User Code All done! Remove USB cable All Security Settings deactivated! Code set to default : 12345 Done! Connect phone on selected interface.. |
02-18-2018, 07:33 | #5 (permalink) |
Major Poster Join Date: Feb 2018
Member: 2806380 Status: Offline Thanks Meter: 4 | nokia 3310 2017 ta-1030 not resetting security code via infinty best and cm2 jayDi ANs pLz i'm in TrOuble... nokia 3310 2017 ta-1030 security Code not working how to flash it... |
07-29-2019, 12:01 | #9 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | User code Quote:
