12-31-2013, 11:21 | #1 (permalink) |
Crazy Poster Join Date: Jul 2010
Member: 1353744 Status: Offline Thanks Meter: 15 | nokia 501 flash error 2 the phone came in hang logo problem.. i flash it with same product code with back casing..but when the proccess flashing,,it is error...the phone is dead now here is the log |
12-31-2013, 17:47 | #3 (permalink) |
Member: 1353744 Status: Offline Thanks Meter: 15 | problem solved,,,on off conector is auto on(short) so flashing always error... repair the on off connector and flash success...tq Dzirt for your help.. here the log Connect phone on selected interface... Core : v1.78 , BB5XG FlashEngine : v8.0 Selected FlashSettings : Manual File [Ok] : rm902_11.1.1.mcusw.fpsx File [Ok] : rm902_11.1.3_059R310_s1_343_03_334883.rofs.fpsx File [Ok] : rm902_11.1.3_059R310_s1_343_03_334883.image.fpsx Dead Mode is Selected Waiting for USB device... If PC not detect phone - Insert Cable first, then Insert battery --- Press phone's power button or insert cable & charger! --- 1st Boot Done, processing booting now ASIC ID_F : 00000C201610004049B221099238382CA4581800 ASIC ID_E : 00000C2016100040 PUBLIC ID : 170F31E576EAA81149B221099238382CA4581800 XGCHIP ID : 170F31E576EAA811 ROOT KEY HASH : 125FC72605B5C4E48A9E0225084D2579 ROM ID : 535882252F54C676 Prepare and send 2nd loader... 2nd boot Ok Prepare and send Algo loader... Algo boot Ok IMEI [1] : 358125050156945 IMEI [2] : 358125050156952 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\358125050156945_2n d_XG223_CRT.rpl PAPUBkeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E === SW Version Check === - > REFLASHING === SW Version Check === === Flashing MCU === Processing file : rm902_11.1.1.mcusw.fpsx Erasing... Writing... Total blocks : 81 Writing RKH CRT [ISSW] Writing RKH CRT [MEMSET] Writing RKH CRT [PRIMAPP] Writing RKH CRT [LOADER] Writing RKH CRT [PASUBTOC] Writing RKH CRT [PAPUBKEYS] [PAKeys : 7E4AA99553DB48A5F2DD39E02FA1B862ECB0EF5E] Writing RKH CRT [UPDAPP] Writing RKH CRT [MCUSW] File processed Ok, 80 blocks were writen === Flashing PPM === Processing file : rm902_11.1.3_059R310_s1_343_03_334883.rofs.fpsx Erasing... Writing... œžB Writing RKH CRT [PPM] File processed Ok, 24 blocks were writen === Flashing CNT === Processing file : rm902_11.1.3_059R310_s1_343_03_334883.image.fpsx Erasing... Writing... Total blocks : 72 File processed Ok, 72 blocks were writen Flashing done , total time : 00:00:30 Reboot phone to service mode... Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 61 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... |
The Following User Says Thank You to cruxxs2000 For This Useful Post: |
