06-04-2008, 10:00 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 71
Member: 174094 Status: Offline Thanks Meter: 74 | nokia 6120flashfile cpu mt6225 2 simcard connector 1...8 read flash fails flashtype EC257E25082501:18A59F00000000 thanks |
The Following User Says Thank You to habibkhalil For This Useful Post: |
06-04-2008, 21:11 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! this is not software version. please make "read detailed information" and post here log |
06-05-2008, 16:03 | #3 (permalink) | |
Member: 174094 Status: Offline Thanks Meter: 74 | Quote:
COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: read/check detailed information Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:4903:000E boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:18A59F00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... . detection phase #2... .................................................. .................................................. ............................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: EC257E25082501:18A59F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF detecting ffs structure pass 1... .................................................. ...... can't detect fat record name location ffs element #1 detection failed detecting ffs structure pass 2... .................................................. ...... can't detect fat record name location ffs element #2 detection failed Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Finished, time used: 80 sec Remove/Install battery now ! | |
06-06-2008, 11:01 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i think your phone firmware is damaged, this is why we cant read it out. please post here picture of phone, maybe someone will recognise it and advice which flash file can be used |
nokia 6303c contact service help.............. | RABIULSK | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 04-09-2010 21:18 |
nokia 6303c contact service help...... | RABIULSK | Universalbox | 5 | 03-30-2010 11:31 |
Nokia 5230 | roder | Universalbox | 1 | 03-29-2010 11:54 |
nokia masters need help.............. | ANILMPLY | Nokia Hardware & Hardware Repair | 0 | 03-29-2010 10:48 |
