04-06-2008, 16:38 | #1 (permalink) | |
No Life Poster Join Date: Sep 2005
Member: 183976 Status: Offline Thanks Meter: 134 | Nokia 6300 "Damaged Firmware" how to fix ? Quote:
04-07-2008, 20:54 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! as long as program did not detect correctly your firmware version- now only way is to try one by one all 6300 firmwares from support site. In eeprom area must be restored your original backup |
04-08-2008, 11:31 | #8 (permalink) | |
Also maybe you need to check phohe hardware (reball CPU and flash chip). You can download many different flash files for 6300 from Infinity-Box support area. | |
04-08-2008, 15:56 | #9 (permalink) |
Member: 183976 Status: Offline Thanks Meter: 134 | You dont believe it but phone can not power after the backup restoring ... but that's what happen and battery is full , i think its a new modele of 6300 with pinout in the PCB ( 5 pin on the pcb ) and 10 pin conector and it can be flashed from the cenector also ... cus there is a conection between the 5 pins in the pcb and 10 pins on the conector .. d u know this medele ??? and here it is the pinout : (the 10 pin conector ) 2 RX 6 GND 7 TX Last edited by asmodi; 04-08-2008 at 16:03. |
nokia 7210c contact service how to fix ? | milandhal | Nokia Base Band 5 ( BB-5 ) | 28 | 05-19-2011 17:54 |
failed SECURITY 6300 How to fixed [SOLVED] | GsmBaguio | Cyclonebox | 3 | 02-23-2010 08:46 |
Cingular branded Nokia E62: How to fix Java Applet issue. | l0h | Nokia Base Band 5 ( BB-5 ) | 3 | 12-28-2006 18:05 |
How to fixed for Nokia 7610 ! ! ! | ThangTruong | Nokia Multimedia | 0 | 03-18-2005 10:08 |
