Old 09-30-2007, 23:05   #1 (permalink)
Ramzan's Avatar
Member: 86597
Sonork: 100.1602630
Thanks Meter: 1,117
Nokia 6300 Dead after formating
Infinity Team please help me
I have China Nokia 6300 Restarting problum
when I formate that with Infinity , software displaed , eeprom address not found Do you want to use standard eeprom address,me press yes.
after some time formate complete but phone is dead
hear is my log file
COM15 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection active
Action: read/check detailed information
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: 98004900000002:2BEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
Initialize Done
Set baud...
115200
Set baud Done
Identification...
device parameters autodetection in progress..
total flash region size: 01000000
detect device identification, method #1...
detection phase #1...
detection phase #2...
warning: identification information not found, possible reasons:
.old firmware type w/o identification data
.damaged firmware
.damaged hardware
detect device parameters finished
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
Can't detect eeprom area
Do you want to use standard eeprom address: 00E00000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard eeprom address selected by user
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 00
eeprom area: 00000000:00E00000-00FFFFFF
detection phase #3...
done
detecting structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
fat location can't be detected
eeprom element #1 detection failed
error: autodetection failed
Finished, time used: 87 sec
Remove/Install battery now !
Old 10-01-2007, 07:53   #2 (permalink)
Super Moderator
acyl2000's Avatar
Member: 1922
Sonork: 100.64645
Thanks Meter: 685
infinity coder aldy make clear b4...this should help u
"ChineseMiracle": How to repair "reboot/restart/freez with SIM card"
1. make full flash backup for emergency case (use 921000 speed for fast operation)
2. select "safe" format method
3. make "format ffs"
4. remove/install battery
5. press and hold phone "Power" button during 30-40 sec to make phone Powered-On
if phone Ok go to step-6
if phone still in reboot/restart/freez state: select "complete" format method and go to step 3
if phone can't Power-On: restore original flash backup
if you don't have original backup: write different firmware files with firmware version similar to original (make ask/rpl if need)
6. restore original imei
7. if phone has touchscreen LCD make calibration: click to LCD corners one by one
if still no luck: check phone hardware
Original Link Here
br
acyl2000
Old 10-01-2007, 08:31   #3 (permalink)
Ramzan's Avatar
Member: 86597
Sonork: 100.1602630
Thanks Meter: 1,117
I tried to write eeprom and firmware but not results because when writing start
software displaed '' writing erar ,writing erae,writing erar and phone deattach
Old 10-01-2007, 08:31   #4 (permalink)
Member: 202611
Thanks Meter: 51
dear friend restore eeprom backup by flashing eeprom ur phone will come alive but in same conditon and do format ffs but this time change format mode and select safe mode ur phone will fine
Old 10-01-2007, 18:21   #5 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,071
During eeprom write press "YES" and write eeprom backup to phone.
if you see other errors during eeprom write process post log here, but never make screenshot, only post here log txt.
nokia 6300 dead after flahing plz help me nishatmohd Nokia Hardware & Hardware Repair 9 02-06-2009 19:22
Nokia 6300 dead after Bb5box? xmans Nokia Hardware & Hardware Repair 3 09-24-2008 06:10
Nokia N8 dead after format..... adnanskyland SpiderMan 2 08-06-2008 09:04
nokia 6300 dead after flashing HIM Universalbox 3 07-13-2007 22:51
Page generated in 0.32600 seconds with 9 queries
