Old 10-10-2008, 11:34   #1 (permalink)
F@RUK S's Avatar
Member: 51153
Sonork: 100.113241
Thanks Meter: 3,673
Nokia 6300 DUAL-BAND pinout need
Nokia 6300 DUAL-BAND Model TB-S6300
i need pinout for it
see photo:
The Following User Says Thank You to [email protected] S For This Useful Post:
Old 10-10-2008, 20:27   #2 (permalink)
Member: 148515
Thanks Meter: 14,733
hello!
i can advice how to detect needed test points by using multimeter
Old 10-11-2008, 09:20   #3 (permalink)
F@RUK S's Avatar
Member: 51153
Sonork: 100.113241
Thanks Meter: 3,673
hello!
how can i do that............?
Old 10-11-2008, 10:17   #4 (permalink)
Chandreshswami's Avatar
Member: 370998
Sonork: 100.1582579
Thanks Meter: 218
How To Find Rx .tx Signles .
1. find Gnd pin (it's required step, you can't continue until you will know Gnd pin location)
2. find Charge pins (it's optional step, just to save your time during future research)
3. find +Battery pins (it's optional step, just to save your time during future research)
4. connect cable Gnd to phone Gnd
5. try to connect cable Rx/Tx wires to all phone contacts one by one (except Gnd, Charge, +Battery pins) and try to read flash from phone
6. if flash read procedure can start this means that pinout found Ok and you can make other operations
HOW TO FIND RX .TX SIGNLES .
It is tasted and also you can test it.
1 step is, we need to find GND from phone.
2 step is, we should power on phone (operation with dead phone:
phone must be 100% dead by software)and take multimater put it to voltage.
3 multimeter (-) line put it GND and with (+) line check each connectors
, and usually Tx= 1.8v or 2.8v and Rx=1.7v or 2.7v
(it will be change by processor but strongly 1.7v or 2.8v not 3v or 4v)
This way is too easy and you will save a more time.
For example!
You have got new brand China miracle phone with USB cable. It has got
12 pin. You must find (Infinity team give good Idea 1.2.3 punkts):
1) GND usually it has got 2 GND. (now we have got 10 pins)
2) We will uncheck USB + and USB- (VSS) just with checking by USB cable (now we have 8 pins)
3) By USB cable we also uncheck V bat+, ac adaptor + polarization (now we have 7 pins)
4) Now from this 7 pins you will find 1 or 3 not used pins (last operation we have 3 or 6 pins to find Rx Tx signals)
5) Now at last operation you should use good multimeter just to find Rx Tx with 1.7v-2.7v or 1.8v-2.8v
6) WHEN PHONE IS POWERD OFF TX AND GND WITH MULTIMETER MAKING BEEEEEP
(DIOD TEST OPERATION), WHEN PHONE POWERED ON IT WILL SHOW LIKE DIOD
RESISTANS 600-700 OHM BETWIN TX AND GND.
Old 10-11-2008, 13:36   #5 (permalink)
Member: 148515
hello!
1. set multimeter to voltage measuring.
2. check bettery voltage, it should be more than 3,7volts
3. set one multimeter probe to some grounded phone part
(if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal)
4. with second probe touch one by one all phone pins (phone battery attached)
(to get better result i would advice to set needle on the end of second probe)
memorise pins with voltage between 2,7-2,9volts.
those are tx/rx
Old 11-11-2008, 00:52   #6 (permalink)
Member: 240988
Thanks Meter: 45
please post photo pinout
Old 11-11-2008, 18:53   #7 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,290
Hello,
What is phone bottom connector type ?
Old 11-12-2008, 01:17   #8 (permalink)
Member: 240988
Thanks Meter: 45
10 pins Konektor
Old 11-12-2008, 11:42   #9 (permalink)
Member: 130995
Hello,
Where is GND pin at phone bottom connector ?
Old 11-12-2008, 14:20   #10 (permalink)
Member: 240988
Thanks Meter: 45
Konektor GND ist pins 10
Old 11-12-2008, 16:41   #11 (permalink)
Member: 130995
Hello,
Where is CHARGE pin at phone connector ?
Old 11-12-2008, 16:58   #12 (permalink)
Member: 240988
Thanks Meter: 45
its same like v3 but they are diiferent becuase they have 10 pins and the photo is posted frome faruks you have to the start line on this page
Old 11-12-2008, 18:28   #13 (permalink)
Member: 130995
Hello,
The Following User Says Thank You to InfinitySupport For This Useful Post:
Chinese nokia 6300 dual sim pin-out tims Chinese Models & Cloned Phones 4 07-31-2009 20:16
Nokia 7390 Dual Band option only xpressmusic Nokia Base Band 5 ( BB-5 ) 1 04-26-2009 05:54
Nokia 6300 original based pinouts Needed .::BHATTI::. Infinity-Box 13 07-22-2008 05:21
switch nokia 5110 dual band odo Nokia Hardware & Hardware Repair 5 02-03-2003 17:24
Page generated in 0.39741 seconds with 9 queries
