10-19-2010, 11:22 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | nokia 6300 need help for eeprom location can't be detected COM3 [VCP0] selected module v3.23 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 353695009840307 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:AA41:31C8 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... error: too many retries during read operation error: can't read required memory area total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... warning: wrong cs at 0x00000438, retry... warning: wrong cs at 0x00000438, retry... warning: wrong cs at 0x00000438, retry... warning: wrong cs at 0x00000438, retry... warning: wrong cs at 0x00000438, retry... warning: wrong cs at 0x00000438, retry... warning: wrong cs at 0x00000438, retry... warning: wrong cs at 0x00000438, retry... warning: wrong cs at 0x00000438, retry... error: too many retries during read operation search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting startup code area #2... ................. startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E22212200:29EA0000000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... ....................... ffs/eeprom: detect std location pass #1... .................................................. ...... ffs/eeprom: detect ext location pass #1... .................................................. .... ffs/eeprom: detect standard offset pass #1... warning: wrong cs at 0x00D9DE34, retry... warning: wrong cs at 0x00D9DE34, retry... warning: wrong cs at 0x00D9DE34, retry... warning: wrong cs at 0x00D9DE34, retry... warning: wrong cs at 0x00D9DE34, retry... warning: wrong cs at 0x00D9DE34, retry... warning: wrong cs at 0x00D9DE34, retry... warning: wrong cs at 0x00D9DE34, retry... warning: wrong cs at 0x00D9DE34, retry... error: too many retries during read operation ffs/eeprom: detect std location pass #2... .. ffs/eeprom: detect ext location pass #2... .. ffs/eeprom: detect ext2 location pass #2... .. warning: ffs/eeprom location can't be detected error: ffs/eeprom detection failed element #2 error: can not detect default imei value Patch required data Fail Finished, time used: 1 min 46 sec Remove/Install battery now ! which file want to flash into mobile? |
10-19-2010, 11:25 | #2 (permalink) |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | if i put read information show this logs COM74 [VCP0] selected module v3.24 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:AA41:31C8 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22212200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb otp offset: 00000000 warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... warning: wrong cs at 0x00000000, retry... error: too many retries during read operation error: can't read required memory area total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... warning: wrong cs at 0x00000438, retry... warning: wrong cs at 0x00000438, retry... warning: wrong data size at 0x00000438, retry... warning: wrong data size at 0x00000438, retry... warning: wrong data size at 0x00000438, retry... warning: wrong cs at 0x00000438, retry... warning: wrong cs at 0x00000438, retry... warning: wrong cs at 0x00000438, retry... warning: wrong cs at 0x00000438, retry... error: too many retries during read operation search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting ffs/eeprom structure pass 1... ....................... ffs/eeprom: detect std location pass #1... .................................................. ...... ffs/eeprom: detect ext location pass #1... .................................................. .... ffs/eeprom: detect standard offset pass #1... warning: wrong cs at 0x00D9A7BC, retry... warning: wrong cs at 0x00D9A7BC, retry... read error recovered ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected warning: wrong cs at 0x00CDC9C0, retry... warning: wrong cs at 0x00CDC9C0, retry... warning: wrong cs at 0x00CDC9C0, retry... warning: wrong cs at 0x00CDC9C0, retry... read error recovered ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished detecting firmware version... firmware version: U26_07B_GEMINI_PCB01_GPRS_MT6226_S01.MAUI_07B_W08_ 16_M9D04.BIN detecting firmware build... .................................................. .... warning: wrong data size at 0x00D99668, retry... read error recovered warning: wrong cs at 0x00D99A68, retry... warning: wrong cs at 0x00D99A68, retry... warning: wrong cs at 0x00D99A68, retry... warning: wrong cs at 0x00D99A68, retry... warning: wrong cs at 0x00D99A68, retry... warning: wrong cs at 0x00D99A68, retry... warning: wrong cs at 0x00D99A68, retry... warning: wrong cs at 0x00D99A68, retry... warning: wrong cs at 0x00D99A68, retry... error: too many retries during read operation firmware date/time: 2009-12-14 22-55 hw1: T26_07B_GEMINI_HW hw2: 07B.01_U26_07B_GEMINI done detecting product-id... .................................................. .............. done detecting languages... ................................................. language parameters detected warning: wrong cs at 0x00C41934, retry... warning: wrong cs at 0x00C41934, retry... warning: wrong cs at 0x00C41934, retry... warning: wrong cs at 0x00C41934, retry... warning: can not detect language names if software freez: make "Find language names (slow process)" unchecked and repeat operation. operation aborted Finished, time used: 2 min 20 sec Remove/Install battery now ! |
10-21-2010, 05:58 | #8 (permalink) |
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | pls understand my questions first of all i did make repaire imei inside soft but i does not get successfully change imei can it get success imei it is need fullfimware of that so can you tell me that firmware from your infinity support |
10-21-2010, 16:48 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! I hope that if you will keep power button pressed there will be no errors during reading/writing. Which in own turn will fix IMEI. can you try "Default IMEI inside firmware" with pressed power button? |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
