10-13-2008, 03:38 | #1 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 246258 Status: Offline Thanks Meter: 46 | LG C1200 Unlock by INFINITY Device: LG-C1100 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 98008400000012:FEEA0000000000 flash: 98008400000012:FEEA0000000000 flash: Toshiba B 8Mb id: 00005250 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 353583000873875 file saved: C:\Documents and Settings\gravity\Desktop\c1200\eeprom_353583000873 875_LG-C1100_20081013-103136.B1E.bin ................................ Check flash Done Check space... current eeprom imei: 353583000873875 ................................ finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 67 sec Remove/Install battery now ! Choose C1100 model Cable FGOLD-011 C1200 unlocking not done with Furious Gold, Done with INFINITY |
The Following 2 Users Say Thank You to gravity06 For This Useful Post: |
10-13-2008, 09:20 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
lg kp235 unlock by infinity very easy | aleem26 | Infinity-Box | 1 | 11-18-2008 11:00 |
LG kp235, unlock by infinity... | alyann | Infinity-Box | 1 | 10-28-2008 16:36 |
need lg cg225 unlock by infinity | sayfulalam | Infinity-Box | 0 | 08-12-2008 08:40 |
<<< LG KG290 unlocked by Infinity >>> | zeel_zeel | Infinity-Box | 1 | 07-28-2008 06:33 |
is LG C1200 supported by RedBox ? | GoGy | Redbox | 2 | 07-05-2004 22:38 |
