Old 10-10-2008, 00:26   #1 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
nokia 6300 newversion detected
i got this nokia with insert sim problem its imei was correct and not faulty
but it can't see any sim i used safe format then rebuilding imei using mode 2 because mode 1 failed
all gone ok but before doing all that i tryed to read full flash and i got new version detected i sent system log and backup to [email protected]
but after format and imei rebuild the phone still has the same problem with insert sim i am asking if this could be hardware or software problem as this phone has new version ?????
The Following User Says Thank You to f164 For This Useful Post:
Old 10-10-2008, 15:52   #2 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
any help p.supporters
Old 10-10-2008, 18:38   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
If you see no changes after \"format\" there is a very big chance that it\'s hardware problem.
At first check sim card holder.
Old 10-10-2008, 22:11   #4 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
Originally Posted by InfinitySupport View Post
Hello,
my question is as this phone has an unknown firmware could this influence on format operation or imei rebuild because mode 1 failed
Old 10-11-2008, 13:31   #5 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
no, format FFS same as IMEI restore will work same good on known and unknow firmware. I think you have some hardware problem. Also, sometimes, some sim cards is too thin. I've met such problem, please check this also
Old 10-11-2008, 13:50   #6 (permalink)
Member: 855834
Thanks Meter: 8
mere khyal se battery dhili hogi packing lagake dekho
Old 10-11-2008, 15:57   #7 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
what you are saying ?
Old 10-11-2008, 16:03   #8 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
hi sir.
pls post here ur fw name...
Old 10-13-2008, 11:41   #9 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 263
Originally Posted by LoveLess View Post
hi sir.
MTK25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_12_03 .BIN]_20081009-234126.B0M.bin
Nokia 6300,3500,3110c Headset Not Detected Hot and New soluation jkniji Nokia Hardware & Hardware Repair 22 12-27-2012 09:13
Nokia 6300,3500,3110c Headset Not Detected Hot and New soluation gsm junction Nokia Hardware & Hardware Repair 1 03-15-2010 11:14
Nokia 6300,3500,3110c Headset Not Detected Hot and New soluation gsm junction Motorola Hardware Repair 0 03-15-2010 11:07
Nokia 6300 mmc detection problem. HICHEM TIGS Nokia Hardware & Hardware Repair 4 08-19-2009 19:13
6300 cant detect any handsfree delchoni Nokia Hardware & Hardware Repair 2 03-23-2009 15:26
Page generated in 0.18943 seconds with 10 queries
