05-21-2010, 08:12 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! most 5pin connector phones do not keep tx/rx in system connector. you must search for test points on PCB. i can teach how to examinate them by multimeter |
05-24-2010, 08:33 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you must attach phone battery, power On phone. and next measure voltages on all available test points or even system connnecotr pins. when you see 2,7-2,9 volts- those will be Tx/Rx |
06-06-2010, 22:41 | #10 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1194696 Status: Offline Thanks Meter: 0 | China Nokia 6700 Hello! Pls. somdebody help me to connect my China Nokia 6700.I'm totaly confused. Only connector which is suitable for it is from infinity pinfinder is cable "L5A". But pin finder can't detect pinout. As I understand from previouse posts. This connector type don't have RX & TX pins. So I should connect directly to main board? If yes pls. give somebody detailed description how to do it and what is next step to flash this phone using China Miracle from infinity. This is realy my favoride BOX. Hope for somebody assistance. Here is some links to pictures: Last edited by timtims; 06-06-2010 at 22:46. Reason: Add picture links |
06-07-2010, 10:56 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! you are absolutely right, now you must disessemble phone and find test points. here is example how this must be done: http://forum.gsmhosting.com/vbb/5530460-post2.html but first please make sure that your phone is MT62xx family phone. otherwise this method will not work |
06-07-2010, 20:59 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! here is common mistakes: 1. do not forget to connect box RJ45 pin 8 with phone grounded part. 2. phone TX must be connected with box RX and otherwise RX with TX. (not TX+TX, RX+RX!) |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
