09-15-2007, 09:21 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: CANADA Age: 42
Member: 149415 Status: Offline Sonork: 100.1609895 Thanks Meter: 77 | nokia 8800i ??? |
09-16-2007, 12:08 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 p.s. next time before send me links to your messages by ICQ please, don't be lazy and check previous messages in this forum. |
09-16-2007, 12:28 | #6 (permalink) | |
Member: 149415 Status: Offline Sonork: 100.1609895 Thanks Meter: 77 | Quote:
and i am not lazy | |
09-16-2007, 12:34 | #7 (permalink) |
Member: 149415 Status: Offline Sonork: 100.1609895 Thanks Meter: 77 | IN FORUM WE DISCUSS TOGETHER about OUR PROBLEMS AND NOT TO DISCRIBE EACH OTHER BY LAZY PPL IF YOU HAVE SOME SOLUTION SAY IT OR DON't TOOK LIKE THAT |
09-16-2007, 13:46 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | You can see 3 steps that helps you to find any pinout: http:///vbb/showpo...15&postcount=5 so, please, don't be lazy and read all 3 link lines that was given to you. |
09-18-2007, 11:56 | #9 (permalink) | |
or in 4 pin under battery near sim holder | |
09-18-2007, 17:27 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | How to find pinout for unknown model Please, follow instruction exactly like described below In most cases you need to know Gnd, Rx, Tx pins for flash/unlock operations. What do do if you don't have cable or you have new phone model: 1. find Gnd pin (it's required step, you can't continue until you will know Gnd pin location) 2. find Charge pins (it's optional step, just to save your time during future research) 3. find +Battery pins (it's optional step, just to save your time during future research) 4. connect cable Gnd to phone Gnd 5. try to connect cable Rx/Tx wires to all phone contacts one by one (except Gnd, Charge, +Battery pins) and try to read flash from phone 6. if flash read procedure can start this means that pinout found Ok and you can make other operations Note about "Chinese models": a lot of different phones with the same name exist on market (as well as many different name phones with the same pinouts), so, if you see in our "cable selector" wrong pinout for "Chinese models" it's good idea to find correct pinout according to above instruction and send new pinout information with full text from phone back label to [email protected] |
help pliz____ nokia 8800i not format or not conecting !!!! | nejm | Infinity-Box | 5 | 10-10-2009 16:58 |
Nokia 8800i cover change? | ChronicDK | Nokia Hardware & Hardware Repair | 1 | 01-03-2009 00:05 |
Nokia 8800i Pinouts needed(Chinese) | .::KHURRAM::. | Infinity-Box | 6 | 09-18-2007 11:30 |
chinese 8800i error(Infinity) | .::KHURRAM::. | Infinity-Box | 2 | 08-21-2007 17:33 |
is there 8800i arabic language | tsarkh | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 12-28-2006 18:59 |
