12-21-2007, 14:04 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Location: South Sumatra, Indonesia Age: 42
Member: 95561 Status: Offline Sonork: 1573725 Thanks Meter: 31 | Nokia Clone N93i Full Backup problem Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... chip: 0031A24:B5A9 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 error: no any expected answer: wrong answer after chip cfi request error: wrong answer[00]: wrong answer after chip id request number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... error: wrong answer[E4] . detection phase #2... error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] .error: wrong answer[00] . warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... error: wrong answer[00] . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 error: wrong answer[00]: wrong answer after chip id request error: wrong answer[FF]: wrong answer after chip cfi request error: wrong answer[00]: wrong answer after chip id request Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size error: wrong answer[0A] Finished, time used: 89 sec Remove/Install battery now ! Whats wrong with my read method ?? |
12-22-2007, 07:49 | #6 (permalink) |
Member: 95561 Status: Offline Sonork: 1573725 Thanks Meter: 31 | i already charge the batt, but still get error log heres my new log, but it look a little different with yesterday log (maybe) COM13 [Serial2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... chip: 0031A24:B5A9 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: H526_05C_PCB01_GPRS_MT6226_S01.H526_05C_V93I.BIN ver. sw2: H526_05C_V93I ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF reading [flash[H526_05C_PCB01_GPRS_MT6226_S01.H526_05C_V93I.BIN]]... warning: wrong cs at 0x00000C00, retry... warning: wrong cs at 0x00000C00, retry... warning: wrong cs at 0x00000C00, retry... warning: wrong cs at 0x00000C00, retry... warning: wrong cs at 0x00000C00, retry... warning: wrong cs at 0x00000C00, retry... warning: wrong cs at 0x00000C00, retry... warning: wrong cs at 0x00000C00, retry... warning: wrong cs at 0x00000C00, retry... error: too many retries during read operation Probably errors exist during flash read operation. Do you want to repeat read operation ? operation canceled by user file saved: D:\1\backup_flash[H526_05C_PCB01_GPRS_MT6226_S01.H526_05C_V93I.BIN]_20071222-134800.B0M.bin Finished, time used: 78 sec Remove/Install battery now ! |
12-22-2007, 11:45 | #9 (permalink) | |
Member: 95561 Status: Offline Sonork: 1573725 Thanks Meter: 31 | Quote:
is there something wrong with these kind cable? I already use it to flash and format ffs many kind chinesee miracle phone. All operation got sucessfull result, except Full Backup operation. | |
12-22-2007, 12:28 | #11 (permalink) | |
Do you have this box/cable too? I Like to be sure with these problem, so i can complain to my reseller where i buy these box and cable. Thanks b4 | |
12-22-2007, 12:33 | #12 (permalink) |
Freak Poster Join Date: Jun 2002
Member: 13289 Status: Offline Thanks Meter: 32 | Don't lose your time to find the error.....contact where u buy the cable/email paklink to give your solution. Infinity software work fine if u have good cable try with 80 cables paklink/unicables infinity for read eprom/fullflash(high speed 921600) |
A35 restore full backup problem... | dimka | x1x to x45/x50 | 3 | 03-22-2002 03:38 |
Nokia 5110 v5.11 Full backup needed. | jonwillow | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-02-2001 18:04 |
Need Nokia 7110 v7.73 full backup.......and where starts the eeprom part??? | thagangsta | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-05-2001 16:17 |
Need Full Backup 20000-40000 Nokia 7110 v4.73 | thagangsta | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 04-26-2001 01:04 |
I still need Nokia 7110 v.4.94 full backup file ! | hjasko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-14-2001 12:35 |
