Old 11-03-2009, 13:36   #1 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 781
After flash 6300 not powerup
PLEASE INFINITY TEAM HELP ME.I DOWNLOAD FLASH SUPPORT AREA AND THEN FLASHED BUT NOW HANDSET NOT POWERUP
LOG ARE
COM5 [VCP0] selected
module v2.96
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: write NOR flash
"smart write" active
write: Firmware
A8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711 _16m_En_Ru_Fr_De_Ml_Th_Vn_Cn_Ar.B0M.bin
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
A8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711 __ffs_01.B0E.bin
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
Initializing [6226:8A02:8A01]...
CPU: MT6226
high speed boot Off
chip: 0031:A3B0:B316
status: FF
high speed boot Off
boot packet size: 0002
Release Power button now !
Boot Done
Initialize ...
flash: EC257E25082501:2BEA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
115200
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is damaged, recalculation required
rom info detection finished
device-id: 3AEFE431
rom info protocol ver: 04
ver. sw 1: A8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711 .BIN
ver. sw 2: A909B_YY01_00_1.0T06_0711, C87562E3
address offset: 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: A8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711 __ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\A8_PCB01_GPRS_MT6 226_S01.A909B_YY01_00_1_0T06_0711__ffs_20091103-172814.B0E.bin
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
sec info (fast) detection...
startup code area #1 check...
startup code area #1 calculation...
startup code area #1 fixed
detecting startup code area #2...
startup code area #2 is absent I THINK THIS ERROR
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\A 8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711_ _system_log_3AEFE431_E36275C8_20091103-173012.B0X.bin
Area: Firmware
Write: Firmware
Area: Eeprom/ffs
Write: Eeprom/ffs
Write Done
Finalization ...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\A 8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711_ _system_log_3AEFE431_E36275C8_20091103-173042.B0X.bin
Finished, time used: 522 sec
Remove/Install battery now !
PLEASE HELP ME
Old 11-03-2009, 15:46   #2 (permalink)
amar181's Avatar
Member: 510122
Sonork: 100.1606547
Thanks Meter: 1,822
You must match fimware versan... If it difrent your fone goes white display or dead....
Br.
amar181
Old 11-03-2009, 20:34   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
we have 3 flash files with this version.
worth to try them all
Old 11-04-2009, 06:35   #4 (permalink)
Member: 585807
Thanks Meter: 781
sir support site only two flashes i try both but sam not power sat
Old 11-04-2009, 06:43   #5 (permalink)
minhajul islam's Avatar
Member: 933507
Thanks Meter: 84
Download Flash File Then Flash
I Think Set Is Ok
Old 11-04-2009, 06:46   #6 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
used format ffs if response and not power again the problem is hardware
Old 11-04-2009, 07:02   #7 (permalink)
Member: 585807
Thanks Meter: 781
i get two flashes on support mt 6226. i try both but problem not solved. i try to used format ffs but set not goes to test mode.
this hand set NOHA AND back model 6300 type rm-166. made in finland
this hand set histrory
it is ok i formate rong and my mistake not read full flash.Now support area two flashes i try two but sam
i know this is software fualt.
INFNITY HELP TOLD we have 3 flash files with this version.BUT i got two
please help
Old 11-04-2009, 13:49   #8 (permalink)
Member: 585807
Thanks Meter: 781
help help helppppppppppppppppppppppppppppppppppppppppp
Old 11-04-2009, 21:04   #9 (permalink)
Member: 148515
hello!
find out which you miss and try it
flashfiles/ChineseMiracle/_MT6226/A8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711 _16m_En_Ru_Fr_De_Ml_Th_Vn_Cn_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6226/A8_PCB01_GPRS_MT6226_S01.A909B_YY01_00_1_0T06_0711 __Nokia-6300-RM-217_16m_En_Ru_Fr_De_Ml_Th_Vn_Cn_Ar.B0M.bin
flashfiles/ChineseMiracle/_MT6205-MT6227/other3/6300_BLUETOOLTH_A8_PCB01_GPRS_MT6226_S01.A909B_YY0 1_00_1_0T06_0711_16m_En_Ru_Fr_De_Malaysia_Th_Vn_Cn _Ar_w_eep.B0M.bin
6300 after flashing charger not supported SE4U Nokia Base Band 5 ( BB-5 ) 3 04-13-2012 14:53
I Got a Problem after Flashing 6300 Meiye Q7 torpedo_seluler Infinity-Box 13 11-04-2010 10:37
It is posible that after flash 6300 phone locked? stylius MT-BOX 4 10-02-2007 16:33
Page generated in 0.25666 seconds with 9 queries
