Old 07-22-2010, 15:28   #1 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
Nokia e71 tv 2 sim flashing
PLS I GET THIS NOKIA E71 FLASH IT SUCESSFUL BUT STILL DEAD...PLS HOW TO REVIVED THIS FONE??? BR COM12 [VCP0] selected
module v3.19
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: write flash
"smart write" active
write: Firmware
CK.ECOPHONE.E71A.E11.F1.1.4.T08D090725__E71TV+++_w _eeprom_16m_En_Fr_Es_Id_Tr_Farsi_Pt_Ar.B0M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001403:0005
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22222201:FFFFFF00000000
flash: Amd AMD/Fujitsu std [def 0100x020000] 32Mb
otp offset: 00000000
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
- damaged firmware
ffs/eeprom address can not be detected, value from database assigned: 00000000/00000000
sec info (fast) detection...
usb bootloader (file) is absent
startup code area #1 check...
done
detecting startup code area #2...
startup code area #2 is absent
Area: Firmware
Write: Firmware
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 12 min 0 sec
Remove/Install battery now !
Old 07-22-2010, 21:55   #2 (permalink)
Member: 148515
Thanks Meter: 14,904
hello!
have you ever successfully read out of this phone it's original software version?
Page generated in 0.18611 seconds with 8 queries
