Old 04-20-2011, 00:38   #1 (permalink)
tattoum's Avatar
Member: 16625
Sonork: 1578753
Thanks Meter: 160
nokia E9 dead help please
phone dead
this is log please what is that
COM6 [VCP0] selected
module v3.26
Device: Autodetect 6228-6253 NAND
Checking data, wait...
Action: read/check information
interface: BROM_DLL_v3.1016.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6253:8A02:8A00
status: FF
bbchip bl ver: FE
NOR flash chip: S_DA_NOR_UNSUPPORTED_DEV_ID
flash id: 0089:010300000000 NOR_UNKNOWN
NAND flash chip: not installed
internal RAM size: 00020000
external RAM: S_DA_RAM_ERROR
done
Set baudrate (921600)...
done
error: no any detected/known flash chip found: 0BC0:S_DA_DEVICE_NOT_FOUND
error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND
Disconnect...
done
Finished, time used: 1 min 4 sec
Remove/Install battery now !
Old 04-20-2011, 09:47   #2 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
Originally Posted by tattoum View Post
phone dead
module v3.26
Connect...
Connecting...
Booting...
CPU: 6253:8A02:8A00
status: FF
bbchip bl ver: FE
done
done
Disconnect...
done
Hello use new version Chinese maricle software 3.30 & select 6253NOR type....
The Following User Says Thank You to rameez_gsm For This Useful Post:
Old 04-20-2011, 21:12   #3 (permalink)
tattoum's Avatar
Member: 16625
Sonork: 1578753
Thanks Meter: 160
i did as you advised but look at log i did on/off "Boot baudrate autoselect but same!!
module v3.30
Device: Autodetect 6253 NOR
advanced flash detection disabled
====> Boot ...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing [6253:8A02:8A00]...
CPU: MT6253
high speed boot Off
chip: 0000:0000:000F
status: FF
high speed boot Off
boot packet size: 0400
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
Finished, time used: 19 sec
Old 04-20-2011, 22:56   #4 (permalink)
Member: 148515
Thanks Meter: 15,713
hello!
what box/cable you are using as interface?
Old 04-20-2011, 23:56   #5 (permalink)
tattoum's Avatar
Member: 16625
Sonork: 1578753
Thanks Meter: 160
infinity box + and using pinout on board as usual may be flash ic is damaged? please help
this is pinout picture
Old 04-21-2011, 09:43   #6 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
Hello change rx tx to one another then post here result.....
Old 04-21-2011, 19:48   #7 (permalink)
Member: 148515
hello!
please use in settings "boot at high baud"
Old 04-21-2011, 22:57   #8 (permalink)
tattoum's Avatar
Member: 16625
Sonork: 1578753
Thanks Meter: 160
i did that, it doesnt boot at all so rx ant tx are correct
Old 04-21-2011, 23:01   #9 (permalink)
tattoum's Avatar
Member: 16625
Sonork: 1578753
Thanks Meter: 160
hello!
i tried it and all options but same result. what could it be? please help
Old 04-22-2011, 10:46   #10 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
Hello bro then problem with your phone try to check on hardware......
Old 04-22-2011, 18:39   #11 (permalink)
tattoum's Avatar
Member: 16625
Sonork: 1578753
Thanks Meter: 160
i think flash ic is damaged, i did rehot it but same result!!!!
Old 04-23-2011, 11:38   #12 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
Hello bro rehot also CPU maybe your problem will be solve......
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
Page generated in 0.39492 seconds with 9 queries
