07-02-2016, 23:50 | #1 (permalink) |
Freak Poster Join Date: Apr 2012 Location: World Age: 37
Member: 1753151 Status: Offline Sonork: 100.1658597 Thanks Meter: 332 | Nokia Lumia 535 RM-1089 unlock via server fail Please refund my credit or help to unlock this set. Code: Card found: S/N : 75E0D74C , v0130 Registered to: bayecheikh Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok [WP8x] : Init TesMode [TSTM] : Use File : RM1089_2048.0000.9651.14192.207.34_enosw-wim-signed_676374_2.secwim === Base Phone Info Device reboot not done Try in Dead mode [WP8x] : Init TesMode [TSTM] : Use File : RM1089_2048.0000.9651.14192.207.34_enosw-wim-signed_676374_2.secwim Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device boot not done Check Drivers, battery charge Try again in Dead mode Card serial: 75E0D74C Card type: BEST Dongle Card password: ZEIOuydh Link to my account: http://user.infinity-best.com Login: lumia11246 Connecting to server... Credits: 76 [WP8x] : Init TesMode [TSTM] : Use File : RM1089_2048.0000.9651.14192.207.34_enosw-wim-signed_676374_2.secwim Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device boot not done Check Drivers, battery charge Try again in Dead mode [WP8x] : Init TesMode [TSTM] : Use File : RM1089_2048.0000.9651.14192.207.34_enosw-wim-signed_676374_2.secwim Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device catched in BOOT mode! Boot Mode confirmed! Setting Preloder Collect Info... Setting Application Setting Secure Collect Info... === Nokia Flash App info : Protocol Version : 2.34 Protocol Implementation : 2.59 === Phone Initial info : Phone RMxxx ID : RM-1089 Phone Model ID : Nokia.MSM8212.P6214.1.1 Phone Model PC : 059W877 Phone IMEI : 355742066900265 === eMMC info : eMMC Vendor : Samsung eMMC CID : 0015 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : BC2353ACA62C327ECCD582A281CA4A5672F35001 === Other info : SD present : False SECWIM : RM1089_2048.0000.9651.14192.207.34_enosw-wim-signed_676374_2.secwim Sending WIM ... WIM Image sent! Trying init TestMode now... Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected Unknown result , something wrong with SDauth or Data #2 , try "Unlock" again Error! Check previous error message for more info! Card serial: 75E0D74C Card type: BEST Dongle Card password: ZEIOuydh Link to my account: http://user.infinity-best.com Login: lumia11246 Connecting to server... Credits: 2 WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Unknown result , something wrong with SDauth or Data #1 , try "Unlock" again! Error! Check previous error message for more info! WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Unknown result , something wrong with SDauth or Data #1 , try "Unlock" again! Error! Check previous error message for more info! WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Unknown result , something wrong with SDauth or Data #1 , try "Unlock" again! Error! Check previous error message for more info! WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Unknown result , something wrong with SDauth or Data #1 , try "Unlock" again! Error! Check previous error message for more info! Check SimLock info Conf key : 8000000000000000 Provider key : 2280100000000000 Country : Switzerland Operator : Swisscom Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= Done! Clearing SimLock code data... SimLock Unlock flag not present! Check SimLock info Conf key : 8000000000000000 Provider key : 2280100000000000 Country : Switzerland Operator : Swisscom Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= Done! Phone disconected! Connect phone on selected interface... [WP8x] : Init TesMode [TSTM] : Use File : RM1089_2048.0000.9651.14192.207.34_enosw-wim-signed_676374_2.secwim Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device catched in BOOT mode! Boot Mode confirmed! Setting Preloder Collect Info... Setting Application Setting Secure Collect Info... === Nokia Flash App info : Protocol Version : 2.34 Protocol Implementation : 2.59 === Phone Initial info : Phone RMxxx ID : RM-1089 Phone Model ID : Nokia.MSM8212.P6214.1.1 Phone Model PC : 059W877 Phone IMEI : 355742066900265 === eMMC info : eMMC Vendor : Samsung eMMC CID : 0015 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : BC2353ACA62C327ECCD582A281CA4A5672F35001 === Other info : SD present : False SECWIM : RM1089_2048.0000.9651.14192.207.34_enosw-wim-signed_676374_2.secwim Sending WIM ... WIM Image sent! Trying init TestMode now... Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected Unknown result , something wrong with SDauth or Data #2 , try "Unlock" again Error! Check previous error message for more info! Card serial: 75E0D74C Card type: BEST Dongle Card password: ZEIOuydh Link to my account: http://user.infinity-best.com Login: lumia11246 Connecting to server... Credits: 2 Phone disconected! Connect phone on selected interface... |
07-03-2016, 04:29 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Download configurator and use it first to set BEST settings. Then unlock again. Next time try to read logs and use search - save own and other time. |
07-04-2016, 14:38 | #3 (permalink) | |
Member: 1753151 Status: Offline Sonork: 100.1658597 Thanks Meter: 332 | Quote:
Code: Conf key : 8000000000000000 Provider key : 2280100000000000 Country : Switzerland Operator : Swisscom Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= Done! Code: WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected Unknown result , something wrong with SDauth or Data #1 , try "Unlock" again! Error! Check previous error message for more info! [img=https://s32.postimg.org/mkw411ttd/Capture_config.jpg] | |
07-04-2016, 14:42 | #4 (permalink) |
Product Supporter Join Date: Mar 2005 Location: in CPU
Member: 128745 Status: Offline Thanks Meter: 16,936 | contact me [email protected] to solve this issue |
07-22-2016, 20:03 | #5 (permalink) | |
The phone is still locked | |
07-23-2016, 06:04 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | You can solve it by yourself. Just select ( download first ENOSW package ) and select SAME OR NEWER version, than in your phone SW, ENO file and repeat operation. |
