Old 03-04-2008, 18:25   #1 (permalink)
Member: 682988
Thanks Meter: 45
Nokia N22 pinout needed?
Hi, I need China Nokia N22 pinout! it's 2x6 pins!
Here is picture of the pcb.
Anyone got this?
thanks
Old 03-04-2008, 18:40   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,407
Dear Friend,
There are different "Chinese" phones with the same name but absolutely different hardware exist on market.
Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware,
different bottom connectors, different pinouts and and has different firmware, so it's impossible to
give any advice about phone pinout only by phone name.
So we recommend you to include the next information in your request regarding pinout:
1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover
2. phone CPU chip name
3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB)
4. attach phone photo
5. attach phone bottom connector photo
6. include information about Gnd and Charge pins on phone bottom connector
After you have this information prepared, you can find pinout by yourself more easy than before,
just check the next detailed description how to get pinout for your model:
1. use "Cable Selector": "Cable selector" at your service...
2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\
3. if not helps, please read: http:///vbb/showpo...36&postcount=7
4. if not helps, please read: http:///vbb/showthread.php?t=433447
Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en
Old 03-05-2008, 10:01   #3 (permalink)
Member: 682988
Thanks Meter: 45
None got this kind of phone before?
It's 2x6 pin:
/ 1 - - - - - - 6 \
/ 7 - - - - - - 12 \
keybord up
GND:8
VPP: 1
TX: ?
RX: ?
need help, tanks.
Old 03-05-2008, 10:27   #4 (permalink)
Member: 148515
Thanks Meter: 16,153
hello!
as long as nobody able to help i can advice fast and easy method to detect needed pins:
measure voltage on all pins and detect needed by voltage near 2,7-2,8volts.
step by step tutroial is in out FAQ section under
"second and tested way..."
Old 03-29-2008, 21:11   #5 (permalink)
ahmed14's Avatar
Member: 389660
Thanks Meter: 60
neeeeeeeeeeed this pinout
Old 04-05-2008, 12:40   #6 (permalink)
ziadi_alaeddin's Avatar
Member: 650956
Sonork: doki-doc gsm
Thanks Meter: 72
Good pinout for N22 RM-56 2x6 pin
8 GND
6 TX
7 RX
tested ok
in infinity box cable UB-CECT006
CECT S560
The Following User Says Thank You to ziadi_alaeddin For This Useful Post:
Old 07-06-2008, 18:15   #7 (permalink)
GSMSERVE's Avatar
Member: 80990
Sonork: 100.1583974
Thanks Meter: 310
Use this one ( tested) :
The Following User Says Thank You to GSMSERVE For This Useful Post:
Old 07-22-2008, 02:27   #8 (permalink)
Member: 214397
Thanks Meter: 4
thanks work 100/100................
The Following User Says Thank You to ghanmi For This Useful Post:
Old 09-06-2008, 21:01   #9 (permalink)
Member: 196054
Thanks Meter: 7
thanx it's work 100%
nokia n91 and nokia v300i pinout needed GOODNESS Infinity-Box 1 04-29-2008 21:26
Nokia N73 pinouts needed astana2007 Infinity-Box 1 03-04-2008 18:22
Nokia N66 pinout need urgent sadaf2706 Various 1 02-01-2008 00:44
nokia tp012 pinout need tenma Infinity-Box 2 01-13-2008 15:15
CHINESE NOKIA N78s PINOUT NEEDED maplegsm Infinity-Box 1 09-04-2007 13:45
Page generated in 0.35282 seconds with 9 queries
