09-24-2011, 23:00 | #1 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1081995 Status: Offline Thanks Meter: 0 | Nokia N8 China "Sim registration failed" or "Sim si nregistrar" [Infinity Box] MModule v4.01 smart-card: connected S/N: xxxxxxxxxxxxx Wait... Action: read/check information Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: H101 Software version: ZMP_QT_CN_OV_HY512_0 Software date: 2000.00.00 Barcode: 03230102716_141616 10 imei-1: 355818021885997 imei-2: 355818021885963 imei-3: 355818021885997 Finished, time used: 4 sec Remove/Install battery now ! Hasta aqui ya identifico el equipo, ahora a repararlo: Action: "repair imei" Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 355818021885997 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 010818021885994 verification Ok Finished, time used: 2 sec Remove/Install battery now ! Me aseguro que se alla escrito bien la información: Action: read/check information Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: H101 Software version: ZMP_QT_CN_OV_HY512_0 Software date: 2000.00.00 Barcode: 03230102716_141616 10 imei-1: 010818021885994 imei-2: 355818021885963 imei-3: 010818021885994 Finished, time used: 3 sec Remove/Install battery now ! Correcto!! Reparamos el segundo: Action: "repair imei" Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-2: 355818021885963 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei-2: 011818021885993 verification Ok Finished, time used: 2 sec Remove/Install battery now ! Leemos nuevamente!!! Action: read/check information Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: H101 Software version: ZMP_QT_CN_OV_HY512_0 Software date: 2000.00.00 Barcode: 03230102716_141616 10 imei-1: 010818021885994 imei-2: 011818021885993 imei-3: 010818021885994 Finished, time used: 2 sec Remove/Install battery now ! Listo!!! Teléfono reparado!!!! |
09-25-2011, 12:41 | #4 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Wr. | |
05-29-2012, 15:15 | #7 (permalink) |
No Life Poster Join Date: Jan 2006 Location: ES-Brazil
Member: 217679 Status: Offline Thanks Meter: 95 | I have three Chinese Nokia N8 MT6235, I can not make it communicate with the GPGDragon and Infinity PCB-P-05B, does not think any pin, if I just solder the wires on the board (hardware)? Is there a way to make him read the pinouts using the MicroUSB cable or PCB? |
05-31-2012, 00:41 | #8 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
some of MTK phones does not communicate by L05B port. in this case you have to search for PCB test points. this is the only way for making them work with software | |
08-25-2012, 21:20 | #9 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Inside you
Member: 204827 Status: Offline Thanks Meter: 46 | [QUOTE=FaTcundo;7746135]Loading data, wait... [Infinity Box] MModule v4.01 smart-card: connected S/N: xxxxxxxxxxxxx Wait... Action: read/check information Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: H101 Software version: ZMP_QT_CN_OV_HY512_0 Software date: 2000.00.00 Barcode: 03230102716_141616 10 imei-1: 355818021885997 imei-2: 355818021885963 imei-3: 355818021885997 Finished, time used: 4 sec Remove/Install battery now ! Hasta aqui ya identifico el equipo, ahora a repararlo: Action: "repair imei" Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-1: 355818021885997 imei write method: mode-1 imei write channel: imei #1 for dual sim/mono CPU new imei-1: 010818021885994 verification Ok Finished, time used: 2 sec Remove/Install battery now ! Me aseguro que se alla escrito bien la información: Action: read/check information Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: H101 Software version: ZMP_QT_CN_OV_HY512_0 Software date: 2000.00.00 Barcode: 03230102716_141616 10 imei-1: 010818021885994 imei-2: 355818021885963 imei-3: 010818021885994 Finished, time used: 3 sec Remove/Install battery now ! Correcto!! Reparamos el segundo: Action: "repair imei" Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... imei-2: 355818021885963 imei write method: mode-1 imei write channel: imei #2 for dual sim/mono CPU new imei-2: 011818021885993 verification Ok Finished, time used: 2 sec Remove/Install battery now ! Leemos nuevamente!!! Action: read/check information Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: H101 Software version: ZMP_QT_CN_OV_HY512_0 Software date: 2000.00.00 Barcode: 03230102716_141616 10 imei-1: 010818021885994 imei-2: 011818021885993 imei-3: 010818021885994 Finished, time used: 2 sec Remove/Install battery now ! Listo!!! Teléfono reparado!!!![ Mate could you tell me which pinout do you use for N8 chinese please, thank you. |
