Old 01-31-2008, 23:50   #1 (permalink)
Registered User
Member: 65987
Thanks Meter: 45
NOKIA N95 2 sim problem
COM8 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: read/check detailed information
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
chip: 0031:E241:8C28
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: A9EA80F098E59F:A9EA8000000000
number of flash chip/regions detected: 00/01
Unknown or damaged flash chip, operation aborted.
Fault reasons:
1. damaged flash chip: replace or resolder/reball flash chip
2. damaged hardware: check hardware, water inside etc.
3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again
4. wrong model selection, try 'NAND' selection
Initialize Fail
Finished, time used: 572 sec
Remove/Install battery now !
pls help infinity team.
Old 02-01-2008, 02:57   #2 (permalink)
Member: 148515
Thanks Meter: 14,899
hello!
this is 100% flash IC hardware fault. my advice is to resolder flash IC if you have such skills.
Problem with N95 2 sim slider TEHGSM Infinity-Box 3 03-28-2008 21:23
Pinout For Nokia N95 2 Sim 18 pin connector MarvelXZ Infinity-Box 1 02-26-2008 00:31
I Face Common Problem In N95 2 Sim Slider chiragsp_codes Infinity-Box 4 11-23-2007 10:43
Page generated in 0.23554 seconds with 8 queries
