02-19-2017, 13:39 | #1 (permalink) |
Freak Poster Join Date: Apr 2010 Location: algeria Age: 48
Member: 1278921 Status: Offline Thanks Meter: 8 | oppo f1s 3gb ram dead http://**********.com/threads/oppo-f...-solution.884/ any one help me!! phone oppo f1s 3gb ram Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 518 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! Operation Failed Elapsed: 00:00:18 Reconnect Power/Cable! |
02-19-2017, 14:49 | #9 (permalink) | |||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Read my post again - FIND STOCK ROM. STOCK ROM. | |||
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
03-27-2017, 03:40 | #11 (permalink) | |
Banned Join Date: Apr 2008
Member: 744438 Status: Offline Sonork: 100.1640287 Thanks Meter: 279 | Quote:
03-28-2017, 09:33 | #12 (permalink) |
Freak Poster Join Date: May 2012
Member: 1763380 Status: Offline Thanks Meter: 86 | any one tested with this kind of phone? just want to read pattern but no luck... Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 6 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! |
03-28-2017, 10:46 | #13 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | Quote:
here is your compatible rom https://mega.nz/#!jEZTVAYS!sdwnHFQMI...KKwqC7R5cao_8Q pasword is : Mr.0Hook and by happy | |
The Following User Says Thank You to rebainoor For This Useful Post: |
03-29-2017, 14:16 | #14 (permalink) | |
Member: 1763380 Status: Offline Thanks Meter: 86 | i,ll try tomorrow thx Quote:
