Old 06-02-2016, 13:33   #1 (permalink)
Member: 1639426
Sonork: khurram136
Thanks Meter: 94
Qmobile t50 cft not calibrate
q mobile t50 hang in logo write flash file but dialer has stopped try tu farmate
phone error CFT NOT CALIBRATE WRITE NV BUT SAME
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
 ====  Wait for phone...
Phone found! [ 16 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7715 eMMC loader v1.1 Inf
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Erasig flash now, please wait ...
Format finished! Reflash phone with normal FW now!
Elapsed: 00:00:18
Reconnect Power/Cable!
Infinity SC Firmware Detected
FW Size : 691 MiB
Load Ok!
Operation : Flash [ v1.18 ]
======= Flash
Files set for flashing :
[ MCU ] : SC77xx Infinity Package
3. Insert cable
Phone found! [ 16 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
PMTManager : Load 0x18 records
PMTManager : PMT Update Ok!
Flashing now
Update BootCode : u-boot-spl-16k.bin
Write Data ...
Write Data Ok!
Update BootCode : u-boot.bin
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write FSImage : prodnv.img
Write Data ...
Write Data Ok!
Write CodeData : sc7715_modem.bin
Write Data ...
Write Data Ok!
Write CodeData : DSP_DM_Gx.bin
Write Data ...
Write Data Ok!
Erase Block : RuntimeData
Erase block ...
Block erase Ok!
Write CodeData : CP2._CP2_WCN_14C_W15.16_Release.bin
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write CodeData : logo_480x800.bin
Write Data ...
Write Data Ok!
Write CodeData : hwinfo.bin
Write Data ...
Write Data Ok!
Write CodeData : boot.img
Write Data ...
Write Data Ok!
Write FSImage : system.img
Write Data ...
Write Data Ok!
Write FSImage : cache.img
Write Data ...
FSImage : Make and Flush SPImage
Write Data Ok!
Write CodeData : recovery.img
Write Data ...
Write Data Ok!
Process : Flush
Flush Ok!
Write FSImage : userdata.img
Write Data ...
Write Data Ok!
Erase Block : INTERNALSD
Erase block ...
Block erase Ok!
Elapsed: 00:03:34
NVM File looks Ok
Operation : Write NV [ v1.18 ]
3. Insert cable
Phone found! [ 16 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Detected eMMC Flash , Structure detect Ok!
Write NVM Part #1 Ok!
Write NVM Part #2 Ok!
Write NVM Part #3 Ok!
Write NVM Part #4 Ok!
Clean DYNV
Elapsed: 00:00:43
Old 06-02-2016, 15:57   #2 (permalink)
Member: 1639426
Sonork: khurram136
Thanks Meter: 94
Need your help plz infinity teem
Old 06-02-2016, 17:47   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Erase flash is NOT A FORMAT FS!!!
Now reflash whole FW with "Update NV" option.
Old 06-03-2016, 14:20   #4 (permalink)
Member: 1639426
Sonork: khurram136
Thanks Meter: 94
after erase and write fw cft not calibrate ok but phone no services or i try check imei
key pad error dialer has been stooped write nv or phone restore same error
3. Insert cable
Device boot not done
Check Drivers
Try again
Operation : Flash Erase [ v1.18 ]
3. Insert cable
Phone found! [ 16 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Elapsed: 00:00:11
FW Size : 691 MiB
Load Ok!
File Info
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand   : QMobile
Device Model   : QMobile
Device CPU     : scx15_sp7715ea
Device IntName : QMobile
Device Version : 4.4.3
Device Compile : 4/18/2015 10:04:58 AM
Device Project : QMobileT50_MP_17_04
Device ExtInfo : QMobile T50
======= Flash
3. Insert cable
Phone found! [ 16 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
[FL] : User decide to make whole erase
[FL] : FLASH_FULL_FORMAT executing , wait ...
[FL] : FLASH_FULL_FORMAT Ok!
[FL] : Enabled NVM update. Will program all NVM images found in FW !
Flashing now
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Update NVM image : nvitem_w.bin
Update NVM Data Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Update NVM image : nvitem_wcn.bin
Update NVM Data Ok!
Erase block ...
Block erase Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Write Data ...
Write Data Ok!
Process : Flush
Flush Ok!
Write Data ...
Write Data Ok!
Erase block ...
Block erase Ok!
Elapsed: 00:02:54
nv write
Phone found! [ 16 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Clean DYNV
Elapsed: 00:00:17
Old 06-04-2016, 15:46   #5 (permalink)
Member: 1639426
Sonork: khurram136
Thanks Meter: 94
infinity teem palzzzzzzzzzzzzzz need help
Old 07-16-2016, 11:59   #6 (permalink)
Member: 1250765
Sonork: NOt Available
Thanks Meter: 28
I have also same Problem plz give us Solution for this Error.
Old 07-16-2016, 12:32   #7 (permalink)
JayDi's Avatar
Member: 462970
Read FW from working phone. Write it to faulty. Should be fixed then.
Old 07-16-2016, 13:36   #8 (permalink)
Member: 1250765
Thanks Meter: 28
My Problem solved with write Nv file from working Phone Thanx .. . .
Old 07-28-2016, 11:39   #9 (permalink)
shahidjanu's Avatar
Member: 1706213
Thanks Meter: 213
i need qmobile t50 nv file
Old 10-28-2016, 15:57   #10 (permalink)
faisal.u7's Avatar
Member: 1028120
Sonork: 100.1607216
Thanks Meter: 90
plz working nv upload i need this
Old 10-29-2016, 04:58   #11 (permalink)
saqib2009's Avatar
Member: 515406
Sonork: 100.1603457
Thanks Meter: 883
https://mega.nz/#!2Y8WQIhT!3WOJ58L37...d8dPhKrJ2UbVjA
flash this firmware and must tick update nvm u r problem solved yesterday i tested and fix
Old 11-16-2016, 09:22   #12 (permalink)
Member: 1532868
Sonork: 100.1640331
Thanks Meter: 36
worng file
Bro This File Is T200 We Need T50......
Old 03-29-2017, 12:57   #13 (permalink)
Mubashir999's Avatar
Member: 2570477
Thanks Meter: 427
T50 Nv File
https://www.4shared.com/rar/Jp4l18uVba/t50_nv.html
Old 03-29-2017, 13:00   #14 (permalink)
Member: 2570477
Thanks Meter: 427
T50 NV File
https://www.4shared.com/get/Jp4l18uV...nload=true#_=_
The Following User Says Thank You to Mubashir999 For This Useful Post:
Page generated in 0.20631 seconds with 9 queries
