04-29-2018, 13:48 | #1 (permalink) |
No Life Poster Join Date: Aug 2012
Member: 1792561 Status: Offline Thanks Meter: 78 | i can't connect Nokia 3 TA-1032 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 156 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:00 Reconnect Power/Cable! where is wrong? i install new 1.58 supplymentry pakage. i check on cm2mt2 v2.00 show legency |
04-29-2018, 14:12 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Select correct model from settings tab-CPU- {SP Select Model[6571-6797]}, then in next line select Nokia 3 in model. Repeat process. Br. Infinity Box Team. |
04-30-2018, 06:32 | #5 (permalink) |
Insane Poster Join Date: Jan 2007 Location: Iran Pole-Dokhtar Age: 36
Member: 431100 Status: Offline Thanks Meter: 18 | you shoul install "Supplementary files package for v1.58" visit this: http://forum.gsmhosting.com/vbb/f296...-58-a-2242009/ |
