Nokia3 ta-1032 Only Vibeate this phone only vibrate and not flashing with any firmware.... Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 510001154D3331457DEC0D42C1A28B6A Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM31E [eMMC] : FLASH_CID : 150100514531334D420DEC7D6A8B54C1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0x5D955D7606CF7DE002A786B601594D90 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6737 , Project : ne1 , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Disabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID NOT supported by BootLoader! [BL_ERROR] : BBID : Break Flashing! This Firmware will kill phone! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! |
tested any firmware : Nokia-3_MT6737M_Heart_FIH_7.1.1_alps-mp-n1.mp1-V1.11_fih6737m.65.nj.n1_P13 Nokia-3_MT6737M_Heart_FIH_7.1.1_alps-mp-n1.mp1-V1.11_fih6737m.65.nj.n1_P68 Nokia-3_MT6737M_Heart_FIH_7.1.1_alps-mp-n1.mp1-V1.11_fih6737m.65.nj.n1_P108 Nokia 3 TA1032 MT6735_171107181032 Miracle Box BY COMBINEFILE NE1-1480-0-00WW-A01 |
please help me...... |
please help me................... |
There is folder - Nokia on support. use FW only from it! In first 3 pages of section you can find atleast 2 topics about such cases. All solved. |
GOOD LUCK |
but not flash... maybe problem is battery ... in this condition Will the battery be charged? |
No need to charge battery When phone only vibrates it does not charged I flashed on 0% battery . |
With Out Mark On Pre-Earse And Mark On Skip Preloader First Do That Select Nokia 3 But Select Nokia3 like that.. https://b.top4top.net/p_838r7asc1.jpg And https://d.top4top.net/p_838iz2az1.jpg https://mega.nz/#!c1c1nIyI!T_4vE-6nz...7EtiCOjJBK6IOM Key:!T_4vE-6nz0u5U-ukjeAWMdrPlxjuG7EtiCOjJBK6IOM ..... do That And U Will Fix Vaibration Mode.. |
Sure Some Thing Wrong On U Phone I Not have a One In My Hand Right Now But Iam sure This Rom Flash It On Cm2 V1.58 with Out Pre Erase U Will Fix U Proplem ?? |
no .... my phone is dead and only vibrating.... and not flashing with any firmware... |
Use FW from support area. Nokia/Nokia3/ folder. Untick preloader. Try flash. Probably need 5-8 try until you catch correct moment, since device randomly reboot to BROM and PRELOADER. |
try many many time... but nothing... cm2 not allow to flash it |
Like That https://e.top4top.net/p_8429pm7n1.jpg |
