Old 01-11-2008, 20:45   #1 (permalink)
AsiaGSM™'s Avatar
Member: 599306
Sonork: 100.1578386
Thanks Meter: 5,136
NOKIS 7500 pinout
i need the pinout of nokia 7500 soame copy china mobile it have on bord rx, tx, vcc, gnd but its rx tx not working it have same jack like orignal 7500 motorola 1x5 mini jack
Old 01-12-2008, 22:50   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
If you can't connect this phone with software via PCB marked points I have no any good advice....
As about 5pins:
1st is Gnd
2nd is Charge
you have 3 more pins to try as Rx/Tx.
Old 01-13-2008, 01:36   #3 (permalink)
AsiaGSM™'s Avatar
Member: 599306
Sonork: 100.1578386
Thanks Meter: 5,136
i Have Found the pin out of nokia 7500 its in its handfree jack
gnd:4
rx:2
tx:1
plz infinity team add them to in ur next pinout update
Old 01-13-2008, 14:00   #4 (permalink)
Member: 130995
gnd:4
rx:2
tx:1
Thank you !
We will add this information in next update.
Old 03-12-2008, 07:41   #5 (permalink)
Member: 295635
Thanks Meter: 18
nokia 7500 format error ?
COM2 selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
9600 autodetect
error: boot phase#2/1 failed
Can't initialize test mode !
Possible reasons:
1. communication fault, repeat required operation
2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method
error: operation failed !
Finished, time used: 3 sec
Remove/Install battery now !
Old 03-12-2008, 07:46   #6 (permalink)
Member: 295635
Thanks Meter: 18
help plz nokia 7500
nokia 7500
full flash file & eeprom
plz uplod sir
Pinouts for Wi-Fi Mobile C5000 Stoyan Infinity-Box 3 04-01-2010 06:06
7500 Pinout bathri525 Nokia Hardware & Hardware Repair 1 09-16-2008 11:07
Nokia 7500 cable pinouts need urgent!!! faisi MT-BOX 2 01-15-2008 14:09
do not scan pinout nokia 7500 RH-37 help me Tamansu SpiderMan 1 12-23-2007 15:45
pinout 7500 hassan1975 MT-BOX 1 10-21-2007 03:01
Page generated in 0.19056 seconds with 10 queries
