07-08-2008, 15:29 | #26 (permalink) |
No Life Poster Join Date: Sep 2002 Location: mauritius
Member: 15162 Status: Offline Thanks Meter: 61 | Have same model any solution to format phone with infinity.when try to find pinout with infinity pin adapter it does not find it. phone is Infineon CPU i think ,have open and see.or maybe link alexis says anyka cpu. Hope we have solution now????? |
07-08-2008, 15:52 | #27 (permalink) | |
Member: 15162 Status: Offline Thanks Meter: 61 | Quote:
sorry forgot to say .the e90 i have it is asking for phone code.have try 1122 1234 5678 anyone have the correct usercode please? | |
07-31-2008, 12:02 | #29 (permalink) |
No Life Poster Join Date: Jan 2007 Location: mumbai india
Member: 432679 Status: Offline Thanks Meter: 118 | nokla e90 i need to do format fss, but their is no format option i made eprom backup also its working nokla e90 software version: 1.12 cable type: 1x20 (L20A) platform: PMB: Infineon e-gold searching adapter at COM7... adapter found, version: 2000 pins: 20, plain power cycles: 1 activation cycles: 10 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... e-gold (A0) result: Rx:4 Tx:5 time required: 29 sec Power On ! what to do next.this cell when switch on ask to do calibiration and the is in cnineese language.. kepad is also not working. COM7 [VCP0] selected Device: IMobile-100 Checking data, wait... Action: read eeprom Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 115200 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\nokla e90\IMobile-100_eeprom-sta_20080731-162234.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\ulc1_i100_eep65535.cfg error: can't load database v.126 reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\nokla e90\IMobile-100_eeprom-sec_20080731-162300.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\nokla e90\IMobile-100_eeprom-complete_20080731-162312.B1E.bin backup critical area Done Check memory... completed Finished, Remove/Install battery now ! Time used: 54 sec |
china nokla e90 | rajufzr | SpiderMan | 2 | 03-12-2010 06:59 |
Nokla E90 | Andra | Infinity-Box | 26 | 09-08-2009 17:43 |
NCKIA / NOKLA E90 communicator | tedyjohar | Chinese Models & Cloned Phones | 1 | 09-07-2009 08:25 |
Any body have Pin Out for Nokla E90 20pin? | bestncheap | SpiderMan | 1 | 05-01-2008 18:05 |
nokla e90 pinout | shama | Chinese Cocktail | 1 | 01-03-2008 09:16 |
