NOKLA N95-2sim pinout please pinout NOKLA N95-2sim cpu 6226BA connector 1....12 i haven't found it in pinout folder nor in forum thanks |
6: Rx 7: Tx 8: Gnd wbr |
original prob shutt down after pwr/on thanks |
hello! if you dont have pinfinder- i can advice you how to find pinout using multimeter |
tell me infinity how to trace pinout |
1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
