Old 02-05-2009, 10:36   #1 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Not able to unlock lg kp100 locked to reliance(smart gsm services) india
HERE I AM POSTING THE LOGS OF LG KP100 WHICH I AM UNABLE TO UNLOCK
I HAVE USED ALL THE METHODS BUT STILL NO LUCK PLS INFINITY TEAM HAVE A LOOK ON IT
READ CODE LOG
COM2 [VCP2] selected
module v1.61
Device: LG-KP100
Checking data, wait...
Action: unlock
read unlock codes
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: .01 ULC2GL RELIANCE KP100 01 FL 91 V10d 404-83 SEP-30-2008 +0
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090205-155751.B1E.bin
loading data...
data loaded
imei: 35588202441080700
reading eeprom-security_35588202441080700...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202441080700_20090205-155751.B1E.bin
reading eeprom-complete_35588202441080700...
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202441080700_20090205-155753.B1E.bin
backup critical area Done
Check memory ...
loading data...
data loaded
code: 89608854
Finished, time used: 12 sec
Remove/Install battery now !
DIRECT UNLOCK METHOD 1
module v1.61
Device: LG-KP100
Action: unlock
direct unlock method #1
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090205-155826.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202441080700_20090205-155826.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202441080700_20090205-155827.B1E.bin
Check memory ...
loading data...
error: source buffer too small: 00000011 instead of 000001DA
error: operation terminated [00FF]
loading data...
loading data...
loading data...
data loaded
code: 89608854
error: not locked or unknown eeprom
Check memory Failed
DIRECT UNLOCK METHOD 2
module v1.61
Device: LG-KP100
Action: unlock
direct unlock method #2 (Airtel etc.)
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090205-155905.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202441080700_20090205-155905.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202441080700_20090205-155907.B1E.bin
Check memory ...
Check memory Done
Write ...
Erasing: eeprom-security
Writing: eeprom-security
probably you need to restore original imei after unlock process
Write Done
HERE IS THE READED FLASH FILE :-http://rapidshare.com/files/194176861/lg_kp100.rar
WBR
sahil2000ind
The Following 2 Users Say Thank You to sahil2000ind For This Useful Post:
Old 02-05-2009, 10:45   #2 (permalink)
.::AZEEM::.'s Avatar
Member: 336212
Sonork: 100.1585000
@ sahil2000ind
Did u try uploud Eprom than unlcok .....
The Following User Says Thank You to .::AZEEM::. For This Useful Post:
Old 02-05-2009, 10:49   #3 (permalink)
Member: 269044
Sonork: 100.1590584
Originally Posted by .::AZEEM::. View Post
@ sahil2000ind
CAN U PLS GIVE ME THE EPROM FILE I WILL AGAIN TRY TO UNLOCK IT
WBR
sahil2000ind
Old 02-05-2009, 10:51   #4 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Originally Posted by sahil2000ind View Post
code: 89608854
How to unlock LG KP100:
1. Make "read unlock codes"
2. Power-On phone with accepted SIM card
3. Type: 2945#*20001#
4. MENU -> SETTINGS (5) -> SECURITY (7) -> (6) -> (1) -> OK -> enter unlock code
Old 02-05-2009, 11:04   #5 (permalink)
Member: 269044
Sonork: 100.1590584
I HAVE DONE THAT ALSO WITH ACCEPTED SIM BUT WHEN I ENTER 2945#*20001# NOTHING HAPPENS
AS FAR AS I KNOW INFINITY-BOX SUPPORT DIRECT UNLOCKING ALSO
PLS CHECK THE VERSION ALSO ITS 30 SEP 2008 SEEMA THAT ITS NOT SUPPORTED
WBR
sahil2000ind
Old 02-05-2009, 11:50   #6 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
WBR
sahil2000ind
after dialing 2945#*20001#
open phone MENU -> SETTINGS (5) -> SECURITY (7) -> (6) -> (1) -> OK -> enter unlock code
Old 02-05-2009, 12:16   #7 (permalink)
InfinitySupport's Avatar
Member: 130995
@sahil2000ind
Try to flash phone with other firmware from support area. It may be that firmware that is in your phone has special operator customization.
Waiting for your results.
Old 02-05-2009, 12:18   #8 (permalink)
Member: 269044
Sonork: 100.1590584
STILL NOT WORKING AT THAT PLACE THERE IS ONLY SECURITY OPTION
I HAVE TRIED WITH THE NEW PANA 1.62 ALSO NOW THE SOFTWARE NOT EVEN ABLE TO RUN THE LOADER
HERE IS THE LOG
module v1.62
Device: LG-KP100
Action: unlock
read unlock codes
Boot ...
loader: standard
type: 4
loading...
next part...
error: can't run main loader:
try to use another loader type
Finished, time used: 4 sec
PLS INFINTY TEAM CHECK THIS BUG
PANA VER 1.61 IS WORKING FINE
WBR
sahil2000ind
Old 02-05-2009, 12:25   #9 (permalink)
Member: 130995
Hello,
Please, double check, is it a problem really exist with v1.62. In fact it was done no changes regarding boot procedure for KP110, it's strange that phone can't boot.
Old 02-05-2009, 12:35   #10 (permalink)
Member: 269044
Sonork: 100.1590584
Originally Posted by InfinitySupport View Post
Hello,
YA I HAVE CHECK IT WITH PANA v1.62 SAME PROBLEM
PANA v1.61 IS WORKING FINE
I AM FLASHING THE PHONE WITH KP100-00-420-V10a_230-01_MAR-06-2008+0_firmware_lp.B1M VERSION
AS SOON IT COMPLETE I WILL POST THE LOGS
WBR
sahil2000ind
Old 02-05-2009, 14:46   #11 (permalink)
Member: 269044
Sonork: 100.1590584
@InfinitySupport
THANKS FOR SUPPORTING URE *******R SO FAST
I HAVE FLASHED THE SET WITH KP100-00-420-V10a_230-01_MAR-06-2008+0_firmware_lp.B1M VERSION FILE ANS THE SET IS NOW UNLOCKED BUT ITS STARTUP LOGO HAS BECOME O2 AND NOT RELIANCE IT NO PROBLEM
HERE IS THE LOGS
module v1.61
Device: LG-KP100
Action: flash write
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-static_20090205-200410.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-security_35588202441080700_20090205-200411.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\LG-KP100_eeprom-complete_35588202441080700_20090205-200417.B1E.bin
Check memory ...
Check memory Done
Write ...
reset...
done
Erasing: Firmware
Writing: Firmware
Write Done
Finished, time used: 391 sec
THE SET IS UNLOCKED AND WORKING FINE
BUT ONE THING MORE I AM HAVING ABOUT 750 PCS TO UNLOCK ANY SUGGESTION HOW TO UNLOCK THEM WITHOUT FLASHING
PANA 1.61 SUPPORT DIRECT UNLOCKING ALSO
WBR
sahil2000ind
Old 02-05-2009, 15:04   #12 (permalink)
Member: 130995
Hello,
We will check you flash backup, probably it will be possible to make direct unlock, but we need some time to check everything.
Old 02-12-2009, 13:37   #13 (permalink)
pallumobile's Avatar
Member: 659890
Very much thanks to the team for there great response and the sahil bhai as well for quoting the problem and the solution as well.
Old 02-13-2009, 21:03   #14 (permalink)
AY29!4LYF's Avatar
Member: 914747
infinity box always reading code on this model look @ d end there is a unlocking code in 8 digit put an non accepted sim card nd press unlock nd put your code read by infinity box keep it up thanks i done more then 150 pcs never error in any single 1 if u unlock an unlocked fone then it gives error error reading data r fone is not locked
i got backup of all of them
br
chack this
http://forum.gsmhosting.com/vbb/show...91#post4154591
Old 02-14-2009, 18:28   #15 (permalink)
Member: 172515
today i unlock kp100 direct unlock method#2 after unlock i restore the original imei phone is working 1000% ok.
The Following User Says Thank You to ahmad bashir For This Useful Post:
help me to unlock lg kp100 with micro-box nikel333 Basic Micro-Box Software Support 4 03-06-2009 13:25
need to unlock lg kp100 reliance gsm handset ameho0102 Infinity-Box 1 03-05-2009 15:59
how to unlock a c1100 locked to orange gorp LG 5 10-25-2004 18:45
how to unlock z105 umts locked to D2 germany? surfer2go QUALCOMM Models (3G) 6 07-07-2004 22:36
how to unlock a n620 locked to german provider??? surfer2go VLSI, Conexant, Skyworks and Old Models 3 06-24-2002 02:10
Page generated in 0.39305 seconds with 11 queries
