07-03-2008, 06:12 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Island Garden City Of Samal,Ph
Member: 14852 Status: Offline Sonork: 100.1608716 Thanks Meter: 503 | i need help w370 tracfone COM15 [VCP2] selected "smart write" active Action: flash Write: Firmware Write: Language Pack Write: Flex Skip: Eeprom Device: W370 Checking data, wait... Connect... Press and HOLD Power button... rom version: 0411 Connecting... error: incorrect certificate Release Power button ! Connect Fail Finished, time used: 8 sec Remove/Install battery now ! |
07-04-2008, 03:21 | #3 (permalink) |
Member: 14852 Status: Offline Sonork: 100.1608716 Thanks Meter: 503 | sw version 001b0075 750420748535 who: sw_cm Time: Mon Jul 16 22:29:18 2007 SW_W370_6.9.75.K3 Version info. CODE.90.01 BOOT.90.05 FMGR.90.81 FLEX_W370_A0_00I this the information....thanks |
07-04-2008, 09:47 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, You can use latest HModule for flashing, but I do not see any reason to flash phone due to firmweare that exist in support area is exactly the same like firmware in your phone. |
07-05-2008, 11:42 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | yes, f.e. HModule_v1.21, select model like "Calypso 16m". But, please, read: http:///vbb/showpo...70&postcount=4 Phone can not be unlocked via flashing with the same files like already exist in phone. |
07-09-2008, 19:32 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Let's return to begin, please read: http:///vbb/showpo...70&postcount=4 If you still want to flash phone you can use W370_6.9.75.K3 flash files from Infinity-Box support area. |
07-10-2008, 07:52 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | You can try to make unlock but I think phone remain locked after unlock. You can try to flash phone but I think phone remain locked after flashing. I hope it is enough clear explanation. If you need more details you can make "search" in this forum and you will see more discussion about this problem. |
07-10-2008, 07:56 | #13 (permalink) |
Member: 14852 Status: Offline Sonork: 100.1608716 Thanks Meter: 503 | any operation not working sir.... i try to flash but error i try to unlock error again but i try to unlock w375 ok problem this w370 tracfone. |
07-10-2008, 19:39 | #14 (permalink) |
Junior Member Join Date: Jul 2007
Member: 553404 Status: Offline Thanks Meter: 0 | Infinity team If the sw has k3 it is not possible to do unlock. I did not do the backup and with different flash I dead my phone. sw version 001b0075 750420748535 who: sw_cm Time: Mon Jul 16 22:29:18 2007 SW_W370_6.9.75.K3 Version info. CODE.90.01 BOOT.90.05 FMGR.90.81 FLEX_W370_A0_00I this the information....thanks Regards |
07-10-2008, 19:56 | #15 (permalink) |
Member: 553404 Status: Offline Thanks Meter: 0 | How alive this phone?, hmodule v1.21 model motorola w377 i still dead Flash w370_6[1].9.75_FLEX_A0_00I_TracFone.34F w370_6[1].9.75_LP_NA1_En_Es_Pt.34P w370_6[1].9.75_Main_H80S_1172910612_ver2.34M Flashing but no alive Regards |
>> W370 Tracfone Unlock << | kasamiko | Infinity-Box | 91 | 10-30-2018 07:53 |
W370 Tracfone Unlock / Flash | bigmac1204 | Scout | 9 | 07-14-2010 07:47 |
W370 tracfone unlock succes using smart-clip | maxieboy | Smart-Clip | 10 | 09-05-2008 07:10 |
problem unlocking w370 tracfone | wakuwaku | Smart-Clip | 7 | 08-04-2008 10:06 |
still moto W370 tracfone | godwin | Infinity-Box | 1 | 03-17-2008 17:19 |
