Old 05-15-2017, 15:39   #1 (permalink)
Member: 390932
Thanks Meter: 5
not flash mt 6582
i cant flash wiko raindbow white
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 16 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164048601A4FE8EB16B
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048601A4FE8EB16B
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0x3333695381B542E2367D58B89B30C9CF
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : s5501 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3950 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000C00000-0x0000000000100000
Erase : 0x0000000002900000-0x000000007D200000
Flash Pre-Erase Done, time used : 00:00:00
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s5501.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first!
Operation Failed
Elapsed: 00:00:18
Reconnect Power/Cable!
Page generated in 0.11728 seconds with 8 queries
