this is not good infinity when i post u vodaphone 225 flashing problem then u and u tell me that i m laier no this is varey bad u know that what is help perheps u dont no what is help [[[[COM3 [VCP0] selected module v1.57 Device: ZTE-225, Vodafone-225 Checking data, wait... Action: flash write Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 00BF:7353 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... backup critical area Done Check memory ... Check memory Done Write ... reset... done Erasing: Firmware error: erase failed: 00400000 Write Failed Finished, time used: 24 sec Remove/Install battery now !]]]]]]]]]]]] |
1st of all for one Qua. do not create new threads , and what is not good ? Infinity Box is the one of BEST boxes witch have 0.01 % bugs so whats BAD ? and about your problem , check bettery must be full when you start flashing , and also possible DAMAGE flash chip need to reball or just Reheat ..... check it post results BR Faisal_Computer |
before you conclude that something is wrong kindly try to other boxes so you'll know it's truly SW problem. Now do it in infinity. now please check battery, check cable, etc... |
hey its hardware problem chek flash ic br Ali.Imran |
chill .... lets see what he did as i say Nr Faisal_Computer |
no my battrey is ok and fully charg you say that flash chip bad no no because [with out sim work fine when insert sim then phone is restart posiotion ] then i try flashing throught infinity my phone is dead then i post u ------what is my mistek {my phone have sst cpu} |
ok why r u hot plz cool down |
Hello, If you have problem with flashing you can try to flash phone like other models from this module. it may be that this flash type can be flashed like other model. |
if phone hang on or auto restart u try flash sw got error, phone will die bicu hw dmg u need fix hw and flash again,phone live again my story china mp4,phone die boot by spider dun see ic flash and it can fotmat by infinity but got error fail address, only need rehot ic flash, phone power on,sw for check problem hw |
last day i have same problem, same logs as yours, so i decided to reheat the flash IC then flash it again and it's done...it's not the INFINITY software fault... |
i think its hardware fault... Quote:
