Old 12-07-2008, 15:41   #1 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
Exclamation this is not good infinity
when i post u vodaphone 225 flashing problem then u and u tell me that i m laier no this is varey bad u know that what is help perheps u dont no what is help [[[[COM3 [VCP0] selected
module v1.57
Device: ZTE-225, Vodafone-225
Checking data, wait...
Action: flash write
Boot ...
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00BF:7353
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
backup critical area Done
Check memory ...
Check memory Done
Write ...
reset...
done
Erasing: Firmware
error: erase failed: 00400000
Write Failed
Finished, time used: 24 sec
Remove/Install battery now !]]]]]]]]]]]]
Old 12-07-2008, 15:50   #2 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
1st of all for one Qua. do not create new threads , and what is not good ? Infinity Box is the one of BEST boxes witch have 0.01 % bugs so whats BAD ?
and about your problem , check bettery must be full when you start flashing , and also possible DAMAGE flash chip need to reball or just Reheat ..... check it post results
Faisal_Computer
Old 12-07-2008, 15:55   #3 (permalink)
lix_DAVAO's Avatar
Member: 144091
Thanks Meter: 73
before you conclude that something is wrong kindly try to other boxes so you'll know it's truly SW problem. Now do it in infinity. now please check battery, check cable, etc...
Old 12-07-2008, 15:55   #4 (permalink)
Member: 153893
Thanks Meter: 266
module v1.57
Action: flash write
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00BF:7353
Connecting Done
Check hardware ...
Check hardware Done
Check memory ...
Check memory Done
Write ...
reset...
done
Erasing: Firmware
Write Failed
hey,what are u taking about?say sorry to infinity team and dont post this again.
Old 12-07-2008, 15:57   #5 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
hey its hardware problem chek flash ic
br
Ali.Imran
Old 12-07-2008, 15:58   #6 (permalink)
Member: 151871
chill .... lets see what he did as i say
Nr
Faisal_Computer
Old 12-07-2008, 16:41   #7 (permalink)
Member: 130995
Thanks Meter: 35,227
Please, explain what you talk about. I can not understand well.
Old 12-08-2008, 05:16   #8 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
no my battrey is ok and fully charg you say that flash chip bad no no because [with out sim work fine when insert sim then phone is restart posiotion ] then i try flashing
throught infinity my phone is dead then i post u ------what is my mistek
{my phone have sst cpu}
Old 12-08-2008, 05:18   #9 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
br
Ali.Imran
mr this is software problem 1000% ok understand
Old 12-08-2008, 06:51   #10 (permalink)
Member: 151871
hi Man , i am using infinity since its released and i have no any problem like you ever , and Erasing: Firmware error: erase failed: 00400000 Write Failed its mean problem in hardware , Please do what i said in my 1st post of this thread. try and post results . just reball it or rehot
Faisal_Computer
Old 12-08-2008, 15:52   #11 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
ok why r u hot plz cool down
Old 12-08-2008, 16:01   #12 (permalink)
Member: 130995
Hello,
If you have problem with flashing you can try to flash phone like other models from this module. it may be that this flash type can be flashed like other model.
Old 12-09-2008, 05:22   #13 (permalink)
freedomqn's Avatar
Member: 347720
Sonork: xxx
Thanks Meter: 204
if phone hang on or auto restart u try flash sw got error, phone will die bicu hw dmg u need fix hw and flash again,phone live again
my story china mp4,phone die boot by spider dun see ic flash and it can fotmat by infinity but got error fail address, only need rehot ic flash, phone power on,sw for check problem hw
Old 12-09-2008, 05:40   #14 (permalink)
Member: 176522
Thanks Meter: 17
last day i have same problem, same logs as yours, so i decided to reheat the flash IC then flash it again and it's done...it's not the INFINITY software fault...
Old 12-09-2008, 05:54   #15 (permalink)
Euan's Avatar
Member: 492345
Sonork: 100.1594007
Thanks Meter: 161
i think its hardware fault...
Write Failed
Mr. Raskal and Cinek, how come Zulea always cracked your update, this is not good mymiela0419 JAF No Tp Unlocker by Cinek 6 04-03-2009 07:01
this is not good for SagMaster mzbrd SagMaster Team OLD Products 4 03-24-2006 09:50
**** mann this is not good only nokia:( senkron24 Phoenix Black Box 1 08-08-2005 17:29
Page generated in 0.23081 seconds with 10 queries
