Old 08-05-2016, 09:52   #1 (permalink)
Tamansu's Avatar
Member: 235782
Thanks Meter: 82
not read firmware MTK - LOCKED with SPRELOADER
Card found : S/N : 1081497F , v0130
Chinese Miracle II [MTK module] v 1.51
Operation : Format FileSystem [ v1.51 ]
Wait for phone...
Phone found! [ 16 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : LOCKED with SPRELOADER
Processing DA stage
Sending and initialize DA ...
[DA_ERROR] : DONE
Boot Error!
Operation Failed
Elapsed: 00:00:11
Reconnect Power/Cable!
Operation : Fix DL Errors [ v1.51 ]
Wait for phone...
Phone found! [ 16 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
[DA_ERROR] : DONE
Boot Error!
Operation Failed
Elapsed: 00:00:09
Operation : Check / Read Info [ v1.51 ]
Wait for phone...
Phone found! [ 16 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
[DA_ERROR] : DONE
Boot Error!
Operation Failed
Elapsed: 00:00:06
Operation : Read Flash [ v1.51 ]
Wait for phone...
Phone found! [ 16 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
[DA_ERROR] : DONE
Boot Error!
Operation Failed
Elapsed: 00:00:08
please help me
Old 08-06-2016, 07:31   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello.
Make Boot unlock procedure. In CM2 - Security, FastBoot tol - unlock.
The Following User Says Thank You to JayDi For This Useful Post:
Old 08-07-2016, 11:36   #3 (permalink)
Tamansu's Avatar
Member: 235782
Thanks Meter: 82
Operation : Read Flash [ v1.54 ]
Wait for phone...
Phone found! [ 5 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
DAgent configured successfully
Connection agent : BROM
DRAM configured from IDB!
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , 2a4GB
[eMMC] : FLASH_CID : 90014A484247346132A40E96E9085397
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID : 0x68D77D6DE362C2650608BB7C21B57807
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : FULL-SPEED
Boot Ok!
Reading Flash Content now ...
USBDL : Error init HSUSB!!!
Operation Failed
Elapsed: 00:00:24
Old 08-07-2016, 11:48   #4 (permalink)
JayDi's Avatar
Member: 462970
Now install drivers again. Something wrong during port reset.
Old 08-25-2016, 06:14   #5 (permalink)
mohamedsafi123's Avatar
Member: 170244
Thanks Meter: 418
Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.54 ]
Wait for phone...
Phone found! [ 48 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
SecCfgVal : 0x07000000
BromVer : 0x0005
BLVersion : 0x00FE
BootLdrSS : LOCKED with AUTH
Processing DA stage
[DA_ERROR] : DONE
Boot Error!
Operation Failed
Elapsed: 00:00:05
Operation : FastBoot : Unlock BootLoader [ v1.54 ]
Power Off Phone , re-connect battery , Insert USB cable!
Wait for phone...
Phone found! [ 47 ]
Sync...
Protocol : 0.5
Device : WT6755_66_SZ_L
Storage : eMMC
BootLoader : Locked
Warranty : Not tampered ( Under Warranty )
Secure : Enabled
ExtraStat : FB Load Supported!
Boot Unlock/Relock init failed! Operation NOT SUPPORTED!
Operation Failed
Elapsed: 00:00:08
Old 08-25-2016, 06:24   #6 (permalink)
.:Sanjh Phoenix:.'s Avatar
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,098
Wait for phone...
Phone found! [ 48 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
[DA_ERROR] : DONE
Boot Error!
Operation Failed
Elapsed: 00:00:05
Wait for phone...
Phone found! [ 47 ]
Sync...
Protocol : 0.5
Storage : eMMC
BootLoader : Locked
Secure : Enabled
Operation Failed
Elapsed: 00:00:08
unlock bl
then try
Old 08-25-2016, 06:29   #7 (permalink)
Member: 170244
Thanks Meter: 418
Originally Posted by .:Sanjh Phoenix:. View Post
unlock bl
then try
try bl unlock but error.operation no supported see second result next pls help me. poblem enter password
Page generated in 0.19384 seconds with 8 queries
