Old 04-08-2016, 14:15   #1 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 443
Question not Supported .....
Wait for phone...
Phone found! [ 13 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : 009800BC009000660076001500010000
eMMC Flash : NOT INSTALLED
Initialize Memory ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0096 , [TOSHIBA] TYBC0A111557KC
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0015 0001
[NAND] : FLASH_LEN : 0x20000000
[NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1
DEV RID : B86FA6CD0C890278741205680340FDD2
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Error read initial info! Make "Identify" first!
Operation Failed
Elapsed: 00:00:10
Reconnect Power/Cable!
Old 04-08-2016, 15:14   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,836
Hello,
Always post full log. What have you tried to do? For Nand it needs to make successful identify first. You can change Nand Init mode if needed to make identify.
If you want to read firmware only just check Nand Extra option and then you can read factory firmware without make identify.
Br.
Infinity Box Support Team.
The Following 2 Users Say Thank You to PASSIONATE_BOYS For This Useful Post:
Old 04-08-2016, 16:19   #3 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 443
this model is G530 ..
Wait for phone...
Phone found! [ 13 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Info read not done Erased phone or unsupported FlashIc?
You can change settings : Settings -> Other -> NAND init Mode
Done!
Elapsed: 00:00:17
what should i do ?
Old 04-08-2016, 16:19   #4 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 443
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Br.
i want it to format by software .. but it is not supported
Old 04-08-2016, 17:13   #5 (permalink)
nessyb's Avatar
Member: 1866877
Sonork: 100.1681933
Thanks Meter: 452
change init mode one by 1....in setting tab... worked 100%
Old 04-08-2016, 17:13   #6 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,836
Change Nand Init Mode settings from : Settings ->Sp: Other -> NAND init Mode
Read info till it is success, like this-
Operation : Check / Read Info [ v1.44 ]
Wait for phone...
Phone found! [ 20 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_EXT : 0xCA01 , 0x8B00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
NAND Flash : 00AD00BC00900055005400AD00BC0000
[NAND] : FLASH_VEN : 0x008A , [HYNIX] H9DA4GH4JJAMCR_4EM
[NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 00AD 00BC
[NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2
DEV RID : 8BE78D44BDB16E2D39D556C96C928215
EXT RAM : 0x10000000
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
After this you can do required operation.
Br.
Old 11-19-2016, 08:08   #7 (permalink)
Member: 2308219
Sonork: 100.1657074
Thanks Meter: 30
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BB_CPU_NME : [MediaTek] MT6571_S00
BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.4.2 on BBID : 0x8B
NAND Flash : 00AD00BC00900055005600AD00BC0000
DAgent sent , init HW now
[NAND] : FLASH_VEN : 0x00A4 , [Hynix] H9DA4VH2GJMMCR_4EM
[NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC
[NAND] : FLASH_EXT : 0800/0040/00/NIM_Px-2
DEV RID : 0xD4A4171FE05A52EF32DF3E006AB83433
EXT RAM : 0x10000000 [256 MiB]
SOC VERIFY : C1
Boot Ok!
Info read not done Erased/damaged phone?
Done!
Elapsed: 00:00:10
Old 11-19-2016, 12:40   #8 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,836
Wait for phone...
Phone found! [ 18 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6571
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:10
Hello,
Change Nand Init Mode settings from : Settings ->Sp: Other -> NAND init Mode and try again.
Br.
Old 02-02-2017, 15:29   #9 (permalink)
Member: 1299548
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BB_CPU_NME : [MediaTek] MT6583|6589_S00
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Running DA ver.3.2 on BBID : 0x86
NAND Flash : NOT INSTALLED
eMMC Flash : 4E0001153030534A1D64004D9D300B43
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , M00SJ
[eMMC] : FLASH_CID : 1501004E4A5330304D00641D430B309D
[eMMC] : FLASH_BRT : 0x00100000 , 0x00100000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0x89CF5775E89D321C64141549D9555C87
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:14
Old 05-22-2018, 13:42   #10 (permalink)
Member: 2770651
Card found : S/N : 583142FE , v0136
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:27
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Running DA ver.4.2 on BBID : 0x94
eMMC Flash : 90014A48384731650507327030494349
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x40000000
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e1G8
[eMMC] : FLASH_CID : 90014A48384731650507327030494349
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x206776ECFD654A6CE821E6B568EA5A7D
EXT RAM : 0x40000000 [1 GiB]
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:20
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:16
Wait for phone...
Phone found! [ 4 ]
Sync...
Open port error , something went wrong!
Boot Error!
Operation Failed
Elapsed: 00:00:00
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:02
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:02
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:02
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Error!
Operation Failed
Elapsed: 00:00:00
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:02
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:09
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:06
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:02
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Error!
Operation Failed
Elapsed: 00:00:00
Wait for phone...
Phone found! [ 4 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:02
i go also on setting >Sp: Other -> NAND init Mode but my problem is not solved
Old 05-22-2018, 15:45   #11 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,836
Wait for phone...
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:27
Wait for phone...
Phone found! [ 14 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Operation Failed
Elapsed: 00:00:20
Hello,
And it will keep giving error until you will not follow correct procedure. It was enough to read logs given by software- "Make "Identify" first!"
Just complete Identify first under Service tab and then proceed to Format after successful read info is done.
Br.
Infinity Box Team.
Old 09-08-2018, 13:48   #12 (permalink)
Member: 1182619
Page generated in 0.62049 seconds with 7 queries
