02-21-2015, 12:25 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | not supported spd phone read file ok infinity read 32 mb flash file and other tool read 8 mb file and also other box read correct codes by flash file here is logs ==== Wait for phone... Phone found! [ 125 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash CAP : 02000000 Check data... Can take some time Error while prepare! Please, send FlashDump + log to support! Elapsed: 00:00:19 Reconnect Power/Cable! Operation : Read User Code [ v1.01 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 125 ] Open Port Failed! Reconnect Power/Cable! Operation : Read User Code [ v1.01 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 125 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash CAP : 02000000 Check data... Can take some time Error while prepare! Please, send FlashDump + log to support! Elapsed: 00:00:14 Reconnect Power/Cable! Operation : Read FullFlash [ v1.01 ] 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 125 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash CAP : 02000000 Read Flash Content Read Ok , collect info Set FileInfo : Model Vendor : china Model Name : m7 Saved to : C:\InfinityBox\CM2SPD\Read_out\SPD6531_02000000___ china-m7.bin Done! Elapsed: 00:03:42 Reconnect Power/Cable! Operation : Format File System [ v1.01 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 125 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok CPU ID : 6531 , FDLStat : 0000 Flash CAP : 02000000 Verify data... Can take some time Error while prepare! Please, send FlashDump + log to support! Reconnect Power/Cable! here is read file https://www.4shared.com/rar/FLwovO30..._china-m7.html |
