01-04-2008, 05:27 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Monterrey, Mexico.
Member: 558475 Status: Offline Thanks Meter: 26 | WHEN MAY UNLOCK Lg Shine ME 970 Of Telcel-mexico not unlock,not read eeprom,not read flash. Any solution. SELECT MODEL KE 970, JUST IS FOR TESTING, EXPECTING TO INFINITY SOON AS SUPPORT. thank infinity-support,Are the best. Last edited by angelcelu; 01-04-2008 at 05:33. |
01-04-2008, 11:26 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | There is no reason to attach screenshots, you can just post here text from software log window. what to do: 1. press and HOLD phone "power" button 2. I have uploaded new software with little bit changed initial communication procedure, so pls test it and let me know about results: http://www.infinity-box.biz/download...na01_v1.37.rar |
01-04-2008, 18:42 | #4 (permalink) |
Member: 558475 Status: Offline Thanks Meter: 26 | backup of flash COM8 [VCP0] selected Device: LG KE970 Checking data, wait... Action: read flash Boot... Press and HOLD Power button now ! loading... boot answer: 02 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0089:887E Connecting Done Check free space... flash chip supported Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Documents and Settings\Administrador\Mis documentos\INFINITY\firmware\backup_eeprom-sta_20080104-102640.B1E.bin reading [eeprom-sta2]... file saved: C:\Documents and Settings\Administrador\Mis documentos\INFINITY\firmware\backup_eeprom-sta2_20080104-102653.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: C:\Documents and Settings\Administrador\Mis documentos\INFINITY\firmware\backup_eeprom-sec_35030526000000100_20080104-102703.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: C:\Documents and Settings\Administrador\Mis documentos\INFINITY\firmware\backup_eeprom-complete_35030526000000100_20080104-102712.B1E.bin backup critical area Done Check memory... reading [flash]... file saved: C:\Documents and Settings\Administrador\Mis documentos\INFINITY\firmware\lg\shine\backup_flash _20080104-111541.B1X.bin completed Finished, Remove/Install battery now ! Time used: 3048 sec Link them step backup of flash.and they send by mail to infinity-help unlock COM8 [VCP0] selected Device: LG KE970 Checking data, wait... Action: unlock Boot... Press and HOLD Power button now ! loading... boot answer: 02 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0089:887E Connecting Done Check free space... flash chip supported Check free space Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Archivos de programa\InfinityBox\Pana01\backup_eeprom-sta_20080104-111847.B1E.bin reading [eeprom-sta2]... file saved: C:\Archivos de programa\InfinityBox\Pana01\backup_eeprom-sta2_20080104-111858.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: C:\Archivos de programa\InfinityBox\Pana01\backup_eeprom-sec_35030526000000100_20080104-111859.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: C:\Archivos de programa\InfinityBox\Pana01\backup_eeprom-complete_35030526000000100_20080104-111901.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 011A Done probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 30 sec The phone is still blocked |
01-04-2008, 20:11 | #6 (permalink) | |
Freak Poster Join Date: Mar 2003 Location: Croatia S.Petrovo Selo Age: 51
Member: 25144 Status: Offline Thanks Meter: 15 | Quote:
01-04-2008, 20:50 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @dale Thank you very much for information ! Could you, please, also send to me operation.log file to check: [email protected] @angelcelu Please, try to flash phone with files from support area. let's see results. |
01-04-2008, 21:50 | #9 (permalink) | |
ok,i send log......... | |
01-07-2008, 04:27 | #10 (permalink) |
Member: 558475 Status: Offline Thanks Meter: 26 | w> unlock ok w> Flashe with the firmware KE970P40-07-V10h-XXX-XX_MAY-11-2007_firmware_En_Ee_Kz_Lv_Lt_Ru_Ua.B1M.bin and KE970P40-07-V10h-XXX-XX_MAY-11-2007_file_system.B1S.bin and unlock ok. w> COM8 [VCP0] selected w> Device: LG KE970 w> Checking data, wait... w> Action: unlock w> Boot... w> Press and HOLD Power button now ! w> loading... w> boot answer: 01 w> Release Power button now w> Boot Done w> Set Baud... w> 921600 w> Set Baud Done w> Connecting... w> flash: 0089:887E w> Connecting Done w> Check free space... w> flash chip supported w> Check free space Done w> Check parameters... w> Check parameters Done w> backup critical area... w> reading [eeprom-sta]... w> file saved: C:\Archivos de programa\InfinityBox\Pana01\des\backup_eeprom-sta_20080106-182641.B1E.bin w> reading [eeprom-sta2]... w> file saved: C:\Archivos de programa\InfinityBox\Pana01\des\backup_eeprom-sta2_20080106-182652.B1E.bin w> loading data... w> data loaded w> imei: 35030526000000100 w> reading [eeprom-sec_35030526000000100]... w> file saved: C:\Archivos de programa\InfinityBox\Pana01\des\backup_eeprom-sec_35030526000000100_20080106-182655.B1E.bin w> reading [eeprom-complete_35030526000000100]... w> file saved: C:\Archivos de programa\InfinityBox\Pana01\des\backup_eeprom-complete_35030526000000100_20080106-182659.B1E.bin w> backup critical area Done w> Check memory... w> Check memory Done w> Write... w> Erasing: eeprom-complete w> Writing: eeprom-complete w> Verifying... w> Verify result: 011A w> Done w> probably you need to restore original imei after unlock process w> Write Done w> Finished, Remove/Install battery now ! w> Time used: 37 sec |
!! e236 of telcel mexico CANT UNLOCK °°°° | ktienda | NSPRO | 17 | 06-04-2009 21:04 |
Mexico Telcel not working with iphone 3G | xmans | Rebel SIM Card | 3 | 04-17-2009 17:55 |
LG KM500d original locked to Telcel-Mexico dead after flash. I need urgent help | elcapitel | FuriousGold | 0 | 11-25-2008 14:42 |
bb5 by Dejan open phones of telcel mexico? | claucorno | BB5 Box by D.K. | 3 | 05-29-2008 04:30 |
