06-17-2018, 02:50
#1 (permalink)
Member: 138781
Thanks Meter: 850 | nyx kiwi-tv mt6261 uncalibrated the cell have error of uncalibrated
log and firmware Quote:
Operation : Read Flash [ v1.58 ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 16 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : 1FBEE36314F0F326C843CD343EFA955C
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x00DC , [MX] MX25U6435E
[0] : FLASH_DIE : 00C2 0025 0037 0000
[0] : FLASH_LEN : 0x00800000
SDS_INFO : 0x007FE000 , 0x00002000
INT_RAM : 0x0000D000
EXT_RAM : 0x00400000
Reading Flash Content now ...
Read Flash now
Read Ok , 8388608 bytes read
Check and collect compile info
File_Info : FISE61A_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F5.bin
FileVersion : MAUI.11C.W13.52.MP.V2.F5
Saved to : C:\InfinityBox\CM2MTK\Read_out\FISE61A_11C_PCB01_g prs_MT6261_S00.MAUI_11C_W13_52_MP_V2_F5.bin
Done!
Elapsed: 00:00:30
Reconnect Power/Cable!
| firmware error uncalibrated--> FISE61A_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F5_error_uncalibrated.bin image this firmwarre this ok, out error
log Quote:
Wait for phone...
Phone found! [ 16 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_SN : EB6F9E30BDC8D4F8A245676F4B069AB6
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Read Flash now
Done!
Elapsed: 00:00:23
| fimware ok--> FISE61A_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F5_ok.bin image test
1. when writing the good firmware to the bad one, it is not left because it is protected and it is only allowed to write to the same cell that made the backup Quote:
======= Flash
Files set for flashing :
[ MCU ] : FISE61A_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F5_ok.bin
Wait for phone...
Phone found! [ 16 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
SOC_VERIFY : 0xC1
Flash now
Erase region , wait ...
Write data , wait ...
Write : FISE61A_11C_PCB01_gprs_MT6261_S00.MAUI_11C_W13_52_ MP_V2_F5_ok.bin
[ERROR] : DA_UART_RX_BUF_FULL
Flash Error!
Check Cable, Battery , try again
Operation Failed
Elapsed: 00:00:42
Reconnect Power/Cable! | 2. just to remove the protection of the cell phone I touch, give format, but I damaged the calibration, so I can restore the imei, unlock, etc.
I hope for your help to support this model.. |
