Old 12-13-2009, 14:04   #1 (permalink)
adreesas's Avatar
Member: 752606
Sonork: 100.1587361
Thanks Meter: 110
o2 x1b unlock done with infinity box
COM6 [VCP1] selected
module v1.31
Device: O2X1b
Checking data, wait...
Action: unlock
Boot...
Connect test-point to Ground !
Press Power button now !
Connecting...
Disconnect test-point !
Boot Done
Check Connection...
Check Connection Done
Set Baud...
Set Baud Done
Check Flash...
Check Flash Done
Check Parameters...
Flash: 0089:885500010001
file saved: C:\Program Files\InfinityBox\BModule\eeprom-00_20091213-180307.38F.bin
Check Parameters Done
Check Space...
flash: Intel 28F640W30-B B 8Mb
Check Space Done
Check Data...
Check Data Done
Erasing...
erase operation not required
Erasing Done
Writing...
Writing Done
Finished, time used: 44 sec
Remove/Install battery now !
Thanks infinity
The Following 2 Users Say Thank You to adreesas For This Useful Post:
Old 12-13-2009, 21:05   #2 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
good info.............
Old 12-14-2009, 07:48   #3 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
Hello,
Thank you every test report with log is very impotent for improving software
Faisal_Computer
Old 12-14-2009, 07:59   #4 (permalink)
Temporary banned !!
Member: 482214
Sonork: 100.1617896
Thanks Meter: 316
probably wrong model selected WHAT I DO 4 THIS OPTION
COM6 [VCP0] selected
module v1.33
Device: O2X1b
Action: flash write
"smart write" active
Write: Firmware
Write: Flex
Write: Language Pack
Skip: Eeprom
Boot...
Connecting...
Boot Done
Check Connection...
Set Baud...
812500
Set Baud Done
Check Flash...
error: Probably wrong model selected.
Continue anyway ?
Check Flash Done
Check Parameters...
Check Space...
error: unknown flash chip: 141A:AA00:13FD:AA00
Flash: 00B0:00B000B000B0
flash: Sharp LRS1386, LRS1395-F2, LRS1828-F2, LRS1392 T 8Mb
Check Space Done
Check Data...
Check Data Done
Erasing...
Erasing Done
Writing...
Write: Firmware
error: error flash command
try#1 to recover erase error#43
try#2 to recover erase error#43
try#3 to recover erase error#43
try#4 to recover erase error#43
try#5 to recover erase error#43
try#6 to recover erase error#43
Writing Fail
Finished, time used: 20 sec
Old 12-14-2009, 08:12   #5 (permalink)
Member: 151871
what is your exact model ?
try
select exact model , give exact flash files , battery should be fully charged and flash again and post results
Faisal_Computer
Old 12-14-2009, 08:20   #6 (permalink)
Temporary banned !!
Member: 482214
Sonork: 100.1617896
Thanks Meter: 316
O2 x1b 902x1bxn but same problam
Old 05-17-2010, 12:19   #7 (permalink)
Member: 355291
Thanks Meter: 20
Where is test point sir
Old 05-17-2010, 15:55   #8 (permalink)
Member: 1043909
Thanks Meter: 60,921
It's on your HDD:
C:\Program Files\InfinityBox\Documentation\Test_point
Old 07-03-2016, 18:08   #9 (permalink)
Member: 1949195
Please help me to unlock my O2 (X1 B) with
IMEI : xxxxxxxxxx
Many thanks in advance
Old 07-03-2016, 18:23   #10 (permalink)
Member: 148515
Thanks Meter: 19,534
IMEI : xxxxxxxxxx
Hello,
You can buy Infinity products here - Infinity-Box - How to buy
alcatle ot-e207 unlock done with infinity box adreesas Infinity-Box 0 12-13-2009 11:41
Unlock lg kp215a done with infinity box EL_SaNdUnGuErO Infinity-Box 6 04-11-2009 20:49
Sonyericsson T250i unlock done with infinity box Shohel_sst Infinity-Box 1 01-20-2009 14:29
my226x unlock done with infinity box souheilh Infinity-Box 0 06-02-2008 19:04
Page generated in 0.27448 seconds with 9 queries
