05-11-2006, 11:56 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: work Age: 11
Member: 195993 Status: Offline Sonork: 100.1653595 Thanks Meter: 128 | O2-X1b UNLOCK PROBLEM AGAIN!!! device:02x1b checking data,wait... boot... phone should be switched off ! press power button now ! connecting... boot done check connection... check connection done set baud... set baud done check flash... check flash done check parameters... err:not locked or unknowen eeprom check parameters fail finished remove/install battery now ! time used:53 sec |
05-11-2006, 11:59 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Are you sure that your phone is sp-locked ? What you see on phone LCD when you insert SIM card ? What is text on phone back label (pls, write full text here) ? If phone really sp-locked, read flash from phone and send to [email protected] and we will check it ASAP. |
05-11-2006, 12:08 | #3 (permalink) |
Member: 195993 Status: Offline Sonork: 100.1653595 Thanks Meter: 128 | thanks for the rapid reply!!! when iv got voda sim in fone the display says- NETWORK LOCK NETWORK CODE the text on bk off fone is O2 X1B 902X1 BXN S/N:GS72601645TGO IMEI:xxxxxxxxxxxxxxx |
05-11-2006, 12:31 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Try to enter one wrong code. Power off phone by Power button (don't remove battery). Try to make unlock again. If it will be no luck read flash and send to [email protected] |
05-11-2006, 13:40 | #5 (permalink) |
Member: 195993 Status: Offline Sonork: 100.1653595 Thanks Meter: 128 | infinity support no luck with that procedure!!! sent a read flash as requested... thanks for ur help and hope u help with resolving the problem... |
09-22-2006, 13:30 | #7 (permalink) | |
All codes/info/software/drivers/manuals you can get here: www.infinity-box.com | |
O2 X1B unlocking software needed | most_powerful | Various | 1 | 07-03-2016 18:19 |
O2 X1b Unlock | mobilepoint | FuriouS II | 14 | 11-08-2006 09:13 |
O2 X1B unlocking | paklink | FuriouS II | 11 | 03-06-2006 06:48 |
O2 X1b unlock | CLIFFORD25502 | Redbox | 27 | 01-13-2006 01:09 |
O2 X1b unlock | CLIFFORD25502 | VygisToolbox | 2 | 09-15-2005 17:19 |
