04-30-2007, 07:02 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | ((( why i can't connect J100 with infinity ))) Br Faisal_Computer |
04-30-2007, 07:15 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: P A K I S T A N
Member: 113943 Status: Offline Thanks Meter: 73 | which cable u r using m used cruiser or setool cable select comport which shows device manager set buad rate 115200 when soft ware says power on connect cable and press power on may be its work fro u |
04-30-2007, 07:39 | #4 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,421 | i just searched some people asked that UC10 cable of CRUISER is working fine on infinity if its true then Please post pinout of that cable thanks and one thing i just forget that i cuted test point !! Br Faisal_Computer |
04-30-2007, 09:16 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! if red light goes On- this means phone in charging mode. in this condition it can not be booted. try to run soft and then connect cable. also check if battery is ok and right com port used |
04-30-2007, 09:22 | #6 (permalink) | |
Member: 151871 Status: Offline Thanks Meter: 71,421 | Quote:
thanks for reply..... !! 1) i was just charged bettery now when i plug bettery into mobile red light off 2) please tell me setting ( i was cutted that testpiont ) step by step 3) you want to say that cable must be plug in com 1 ( rts and cts ) Br Faisal_Computer | |
04-30-2007, 09:36 | #7 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Follow the instructions, Everything shld be done in a proper way. 1) Make Test Point as described by Infinity (If Required) 2) Connect InfinityBox and proper cable with infinityBox Run the proper software 3) Select Proper Com Port incase ur using USB Port check in Device Manage The port No. 4) Select Proper Baud Rate. 5) Select Proper Flash Files (If flashing Required) 6) Clicke Strat Button and when Software ask u for Press power Button just insert the cable. 7) If not detect automatically press and hold pwer btn as described by the software(Sometime says only press power button sometime says press and hold power button) NOTE : FOR EVERY ACTION BETTERY SHLD BE FULLY CHARGED. Take Care ENJOY |
04-30-2007, 09:50 | #8 (permalink) | |
i was try all these what you said but mobile not detecting and i also use com 1 its also not working Br Faisal_Computer | |
04-30-2007, 09:59 | #10 (permalink) |
Member: 113943 Status: Offline Thanks Meter: 73 | why u cut the track i mean test point i unlocked so many sets never use any test point just connect and unlock so now u need first repair ur cutted track and try again as infinity team said |
04-30-2007, 10:04 | #11 (permalink) | |
yes ...... let me sold it back and test it witch cable are you useing and Please post here pinouts of it Br Faisal_Computer | |
Successfully worked on J100 with Infinity?Share Us | meisam | Infinity-Box | 114 | 01-01-2010 17:25 |
why i can't connect this phone?? | kevin168 | Infinity-Box | 15 | 11-14-2007 22:39 |
why i can't use MiniGPS with some patch. | blazefr | Siemens-Benq Flash Patching | 0 | 06-02-2005 07:09 |
Problem... Can't connect Gthing with Lg3 :( need help | the_frightener | LG | 1 | 05-17-2005 09:47 |
LG 5300 why i can't Connect my Phone ?? | newland | LG | 2 | 08-05-2003 17:28 |
