06-23-2006, 06:12 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | O2x1b Network Locked is Blocked..See THIS COM1 selected Device: O2X1b Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... FLASH: 0089:8855 Check Space Done Check Data... Check Data Done Erasing... Erasing Done Writing... Writing Done Finished Remove/Install battery now ! Time used: 92 sec All Done Ok...Right Infinity Team But guess what It Shows NETWORK LOCK IS BLOCKED..where Before it was Asking for NCK CODE.... I unlock Same Phone in few Seconds with FB GOLD..with Simple Unlock Button....U got Some BUG in it..or New Version having Some Problems....PLZ check ur B module.. WBR |
06-23-2006, 06:19 | #2 (permalink) |
No Life Poster Join Date: Jan 2005 Location: anywhere there is freedom Age: 47
Member: 106700 Status: Offline Thanks Meter: 47 | flash it with falsh file from infinity. pls tick "smart write". infinity box will not make a complete flash but a sort of patch. after 10 secs, u will have an unlock phone. tested by me who have a phone with block menu. |
06-23-2006, 06:22 | #3 (permalink) |
Member: 91045 Status: Offline Thanks Meter: 8,696 | Well As i said I have Unlocked it and Returned to Customer....Infinity u Should add a Little Help file for Such Module supported models Unlocking Procedure....with Installer |
07-17-2006, 07:33 | #5 (permalink) | |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | Quote:
yes pinout on support page is correct | |
07-17-2006, 14:23 | #7 (permalink) |
No Life Poster Join Date: Dec 2000 Location: uk
Member: 2899 Status: Offline Thanks Meter: 6 | same here,had to unlock it 3times,i had the same problem with o2x1i,first it said its unlocked ok,then when i turnd the fone on,net unloc,turnd the fone off then on again it was unlocked! |
07-17-2006, 14:27 | #8 (permalink) |
No Life Poster Join Date: Jan 2002 Location: 24° 51′ 36″ N, 67°
Member: 8353 Status: Offline Sonork: 113276 Thanks Meter: 335 | same thing happened with me in C168 ..i powered on mobile and left it for 2 hours after 2 hours it was again in asking nck code condition |
07-27-2006, 21:46 | #9 (permalink) |
Insane Poster Join Date: Jan 2005 Location: KG
Member: 103940 Status: Offline Thanks Meter: 4 | But i couldn't connect phone, infinity even didn't give any sign of connection, just "power the phone on", I've made tp, changed rx and tx, used different interfaces unibox, pl2303, com. Connector was taken from HF. mb problem was in phone. Now i have another one, design is the same even system connector, but under battery there's written TCL. |
where is evrybody see this numbers | alialjorany | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-17-2010 17:14 |
How to know on WHICH network it is BLOCK? | zakiyyboss | BlackBerry (RIM) | 3 | 08-08-2008 12:39 |
CID52 the SETOOL3 solution network locks is not free? | shumrtong | SETool2 | 9 | 11-21-2007 22:52 |
