10-20-2006, 15:18 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: lahore Age: 43
Member: 139020 Status: Offline Thanks Meter: 15 | O2X1i dead after flash Now i again try to flash i get error try to recovery write error [00:44:00000000] try to recovery write error [01:5D:00000000] try to recovery write error [00:44:00002000] try to recovery write error [01:5D:00002000] Err: no any answer Writing Fail Finished Remove/Install battery now ! Time used: 31 sec How can i fix this bug. when i uncheck smart flash and verify data options, i get full flash but set don't power on. But whenever i check these options i get above error. Plz help me |
10-20-2006, 15:49 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, use fully charged battery. use latest BModule from support area. check phone hardware (maybe water, maybe bad flash chip, maybe flash bad soldered). |
10-20-2006, 16:57 | #3 (permalink) |
Member: 139020 Status: Offline Thanks Meter: 15 | COM4 selected Device: O2X1i,O2XLI Checking data, wait... Action: Flash write Smart Write active Write: Firmware Write: Flex Write: Language Pack Skip: Eeprom Boot... Phone should be Switched OFF ! Connect test-point to Ground ! Press Power button now ! Connecting... Disconnect test-point ! Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0089:885500010001 Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Write: Firmware Flash: 0089:885500010001 Write: Flex Write: Language Pack Writing Done Finished Remove/Install battery now ! Time used: 46 sec i have used full charged battery now this message shows me sofware. Plz guide me. If set has bad flash ic than what i should do. should i heat the ic? |
6300 dead after flash 6233 dead after flash | mobileZONE | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-27-2010 01:17 |
Dead 9210e Orange UK Dead after flashing :( | PhantomGSM | Trisha & Matrix Flasher | 4 | 05-06-2009 12:02 |
benQ o2x1i white dead after flash | falak | Redbox | 1 | 09-20-2005 21:28 |
