08-27-2009, 11:17 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Egypt Age: 41
Member: 153397 Status: Offline Sonork: 113032 Thanks Meter: 372 | why pinfinder work only chinese miracle it ex COM8 [VCP3] selected module v1.69 Device: ZTE-125 Checking data, wait... Action: reset Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... error: can't run main loader: Finished, time used: 22 sec Remove/Install battery now ! |
08-28-2009, 10:18 | #3 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Islamabad--Pakistan
Member: 194128 Status: Offline Thanks Meter: 303 | error: can't run main loader: This error is due to low voltages from your PC's USB Port. So please carefully check your USB Cable, better to use some high quality Shielded wire. Otherwise your PC is not giving enough and proper voltages at USB Port. So please first of all try on some other PC to diagnose that what the probelm exactly is. BEST OF LUCK! yawarniazi |
The Following User Says Thank You to yawarniazi For This Useful Post: |
Help chinese miracle & pinfinder | msashami | Infinity-Box | 2 | 01-02-2009 14:07 |
n68 connects with pinfinder,but cant connect in chinese miracle | GOODNESS | Infinity-Box | 13 | 07-24-2008 21:33 |
Chinese Miracle cable set, where?? | armkbdotcom | Infinity-Box | 34 | 03-02-2008 11:45 |
Chinese Miracle cable set needed ASAP | armkbdotcom | Wanted Products | 1 | 01-19-2007 02:55 |
Why Camcoder Pro works only at 7.5 fps? | mealos | Nokia Multimedia | 6 | 01-04-2005 02:40 |
