O2X1i UNLOK DONE BUT ERROR>>>>>>> i did unlok it but it IS showing limit service... i have no backup....i did write repair eprom but same problem plz help... thanx AK' |
What was problem with the phone when you recieved it? Post unlock log. Have you checked imei, as limited service can be due to invalid imei also!! Wr. |
Yes may be invalid imei...but can i change imei???? Ak' |
Post unlock operation log. Wr. |
http://st2.gsmarena.com/vv/pics/o2/o2x2_00.jpg O2X1i_repair_eeprom_01.37E.rar O2X1i_repair_eeprom_02.37E.rar O2XLI_repair_eeprom_01.37E.rar if not work then try this U Can Unlock Without Risk(Dont Worry If Module Shows Probably Wrong Model Selected) just Press Continue Hope Flashing Supported Will Be Soon Just Select Model BenQ-Siemens----> S660C And Cable L4A here is log Application: C:\Program Files\InfinityBox\BModule\BModule.exe Loading data, wait... [Infinity Box] v1.31 S/N: 6A81:0112 Wait... Device: O2X1i,O2XLI Done Device: BenQ-S660C ==== log: [4/21/2009 4:57:03 PM] ==== COM2 [VCP1] selected module v1.31 Device: BenQ-S660C Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 812500 Set Baud Done Check Flash... error: Probably wrong model selected. Continue anyway ? Check Flash Done Check Parameters... Flash: 0089:88C500010001 file saved: C:\Program Files\InfinityBox\BModule\eeprom-00_20090421-165727.78F.bin file saved: C:\Program Files\InfinityBox\BModule\eeprom-01_20090421-165733.78F.bin file saved: C:\Program Files\InfinityBox\BModule\eeprom-02_20090421-165735.78F.bin file saved: C:\Program Files\InfinityBox\BModule\eeprom-03_20090421-165737.78F.bin file saved: C:\Program Files\InfinityBox\BModule\eeprom-04_20090421-165740.78F.bin Check Parameters Done Check Space... Flash: 0089:88C500010001 flash: Intel I28F320C3B-B B 4Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Flash: 0089:88C500010001 Flash: 0089:88C500010001 Flash: 0089:88C500010001 Flash: 0089:88C500010001 Flash: 0089:88C500010001 Writing Done Finished, time used: 47 sec Remove/Install battery now ! |
