Old 03-12-2011, 14:43   #1 (permalink)
AbDuLlAH kHaWaR's Avatar
Member: 1442994
Thanks Meter: 140
O2X1i UNLOK DONE BUT ERROR>>>>>>>
i did unlok it but it IS showing limit service...
i have no backup....i did write repair eprom but same problem plz help...
thanx
AK'
Old 03-12-2011, 14:57   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,985
What was problem with the phone when you recieved it?
Post unlock log.
Have you checked imei, as limited service can be due to invalid imei also!!
Wr.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 03-12-2011, 15:08   #3 (permalink)
Member: 1442994
Thanks Meter: 140
Yes may be invalid imei...but can i change imei????
Ak'
Old 03-12-2011, 15:45   #4 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,985
Post unlock operation log.
Wr.
Old 03-12-2011, 15:53   #5 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 889
thanx
AK'
Try with this
O2X1i_repair_eeprom_01.37E.rar
O2X1i_repair_eeprom_02.37E.rar
O2XLI_repair_eeprom_01.37E.rar
if not work then try this
U Can Unlock Without Risk(Dont Worry If Module Shows Probably Wrong Model Selected) just Press Continue Hope Flashing Supported Will Be Soon
Just Select Model BenQ-Siemens----> S660C And Cable L4A
here is log
Application: C:\Program Files\InfinityBox\BModule\BModule.exe
Loading data, wait...
[Infinity Box] v1.31
S/N: 6A81:0112
Wait...
Device: O2X1i,O2XLI
Done
Device: BenQ-S660C
==== log: [4/21/2009 4:57:03 PM] ====
COM2 [VCP1] selected
module v1.31
Device: BenQ-S660C
Checking data, wait...
Action: unlock
Boot...
Press Power button now !
Connecting...
Boot Done
Check Connection...
Check Connection Done
Set Baud...
812500
Set Baud Done
Check Flash...
error: Probably wrong model selected.
Continue anyway ?
Check Flash Done
Check Parameters...
Flash: 0089:88C500010001
file saved: C:\Program Files\InfinityBox\BModule\eeprom-00_20090421-165727.78F.bin
file saved: C:\Program Files\InfinityBox\BModule\eeprom-01_20090421-165733.78F.bin
file saved: C:\Program Files\InfinityBox\BModule\eeprom-02_20090421-165735.78F.bin
file saved: C:\Program Files\InfinityBox\BModule\eeprom-03_20090421-165737.78F.bin
file saved: C:\Program Files\InfinityBox\BModule\eeprom-04_20090421-165740.78F.bin
Check Parameters Done
Check Space...
flash: Intel I28F320C3B-B B 4Mb
Check Space Done
Check Data...
Check Data Done
Erasing...
erase operation not required
Erasing Done
Writing...
Writing Done
Finished, time used: 47 sec
Remove/Install battery now !
Thanx, but it doesn't work 1aitunon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 06-17-2001 11:16
Unlocked network on 5110v5.28 does not make calls, but other network does? Prodigal Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 03-01-2001 16:43
NOKIA 5110 5.29 all locks OPEN but SIM CARD NOT ACCEPTED elektron code ECS Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 01-10-2001 17:40
FBUS works but MBUS not! PLS Help! Upo Nokia Hardware & Hardware Repair 5 09-12-2000 15:54
6110 unlocked but wont give reception KingOfKingston Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 04-10-2000 23:15
Page generated in 0.29304 seconds with 8 queries
